When should the crank be upgraded
Old May 15, 2021 | 07:01 PM
Brad24's Avatar
Brad24
Default When should the crank be upgraded
I’m thinking of going to a 107 or 110 with head work etc on my 2010 FXDF
At what HP & torque level should the standard crank be upgraded?
Thanks
Old May 16, 2021 | 07:20 AM
prodrag1320's Avatar
prodrag1320
Thanks
there is no "written in stone" rule on this,i tell our customers its a good idea on any buid & not to do so is a crap shoot at best.
Old May 16, 2021 | 07:39 AM
Mattbastard's Avatar
Mattbastard
When you're going to increase the stroke.
Honestly, make sure yours is true and run it. Unless you're making a drag racer engine for bracket racing you don't need a crank for a 110ci build.
Old May 16, 2021 | 08:17 AM
Brad24's Avatar
Brad24
What happens when the cranks fails typically?
I drag race a SBF sedan we turn to 8K
so I’m used to carnage lol
Old May 16, 2021 | 09:13 AM
skills's Avatar
skills
All it took my stock 06 TC crank to fail was 551 cams & a Power commander V. I never run my bike hard, in fact it's rather pampered. I wish HD would be proud and spend an ounce more energy on their whimpey cranks.
Old May 16, 2021 | 04:26 PM
GrovenSportster's Avatar
GrovenSportster
I mean it's like they cut every possible corner to save money and then still charge premium prices for their bikes. Lol!
I guess it's just like anything else, guns, cars, airplanes etc., good enough is never good enough for a lot of us.
Remember what Vinny Gambini said.........................
Old May 17, 2021 | 06:46 AM
prodrag1320
we`ve seen way more cranks loose the rod bearings than going out of true to where its actually a problem,this is one of the reasons we recomend going to a S&S crank over just rebuilding & plugging a OEM crank.the OEM rods without races are a very poor idea that dosnt work very well
Old May 17, 2021 | 07:02 AM
Brad24's Avatar
Brad24
Thanks mate
Old May 17, 2021 | 10:20 AM
Max Headflow's Avatar
Max Headflow
I thought the later TC SnS cranks don't have races. It was only the ones with the 1.5 inch crank pin that had the races. IMO they weren't very good cranks.
Old May 17, 2021 | 10:39 AM
skills's Avatar
skills
Yup,I went to a 4 3/8 stroke S&S. I don't have many miles of proving it but I do anticipate much better results
