Carb pop
Old Jul 18, 2021 | 07:49 PM
Chevy guy's Avatar
Chevy guy
6th Gear
Default Carb pop
Hey guys. I have an 80 fxef shovelhead. Runs fine. Starts right up every now when idling it will randomly pop through the carb and sometimes shut off but then starts right back up. Any advice on where to look? S&S carb don't know much else being I just got the bike not long ago.
Old Jul 19, 2021 | 08:11 AM
bustert's Avatar
bustert
dual fire?
electronic or points?
idle rpm?
carb properly adjusted?
not every cylinder will fire every time and on a dual fire this becomes evident with cough back die syndrome. my 74 ch would do it, went to electronic and for the most part ended the issue. i use the no bells no whistles compu-fire system and accell 50k coil. it seems the beast knew when to do it when you are in a bind and need to go. i installed an electric foot. i also run the mikuni vm round slide carb and that ended the accel pump being needed. also cold starts was a one lever push and no touch throttle.
Old Jul 19, 2021 | 08:59 AM
Chevy guy's Avatar
Chevy guy
6th Gear
New to working on bikes but it is electronic single fire s&s super e adjusted properly (from everything I looked up and tried) I will get a pop or to on take off from time to time and also just idling. Problem is intermittent
Old Jul 20, 2021 | 09:26 AM
bustert's Avatar
bustert
stock ign? does coil have two or three primary terminals?
on take off, the accel pump could be an issue.
might try richen the idle, a lean out can cause cough back
Old Jul 20, 2021 | 07:20 PM
pgreer's Avatar
pgreer
Sounds like a lean condition, so the above mentioned items, and check for a vaccum leak at the manifold. I believe the 80 shovels used the large band seal, but they can still split and leak.
Paul
Old Jul 21, 2021 | 07:41 AM
bustert's Avatar
bustert
super +1 mr. pg
there were the band and o-ring
i use high temp glass tape like used in oven wiring on top of the seal. two reasons, holds it in place while fiddling with the clamps and second, it seals the joint when engine heat meets the adhesive. this is a bear to get off but it will not leak. does not take much, about one wrap forward and one reverse.
89FLHTC
Carburetor Related
May 6, 2016 11:40 AM
RSDUDA
Shovelhead
Dec 29, 2014 02:37 PM
amfhd
Shovelhead
Dec 12, 2009 01:47 PM
dert
Exhaust System Topics
Feb 3, 2006 10:26 AM
Beeracuda
13
Dec 27, 2005 03:16 PM
