Intake Push Rod tight when rear piston is at TDC
Old Sep 13, 2021 | 06:35 PM
WyoEglide52's Avatar
WyoEglide52
Default Intake Push Rod tight when rear piston is at TDC
So following the HD Manual for my 2001 Eglide with Twin Cam 88 engine, to find TDC on the rear piston I put my finger on the intake lifter, I turn the rear wheel forward until the lifter goes up and and keep turning until it goes down. Then I put my finger over the rear spark plug hole and turn the rear wheel forward until the air stops escaping from the cylinder. I use a wooden paint brush to verify the piston is all the way up. TDC. I bolt down the rockers assembly and allow for the lifter bleeding down. The exhaust push rod will spin freely. The intake push rod will not spin. I’ve unbolted and bolted it back down 3 times with the same result. I allowed a couple of hours for the lifters to bleed down.
I’m doing something basic in the wrong way. But I don’t know what. ??
I’m wondering if I took the rockers apart when it was on over lap instead of TDC? But both push rods would spin so. Not sure.
Last edited by WyoEglide52; Sep 13, 2021 at 07:10 PM. Reason: Add something to my text.
Old Sep 13, 2021 | 11:34 PM
Max Headflow's Avatar
Max Headflow
Could you have the pushrods swapped?
Old Sep 14, 2021 | 02:29 AM
vonh12's Avatar
vonh12
Are you on the right stroke??
Old Sep 14, 2021 | 05:47 AM
rigidthumper's Avatar
rigidthumper
Short pushrod is intake, long is exhaust. If they are swapped, this is exactly what happens.
Old Sep 14, 2021 | 06:34 AM
WyoEglide52
I will double check the push rods. 99 3/4% sure I’m in the right stroke. Will double check stroke too. It’s a new day. Anything could happen. I might even get it right the first time! Thanks.😎👍
Old Sep 14, 2021 | 08:26 AM
WyoEglide52
I have the pushrods in the correct lifter bores. And I am at TDC. I wonder it it would hurt if I tighten down the rockers assembly and let the lifters bleed down. Not torque it yet. Then if the intake rod is still tight, just rock the rear tire slightly to see if the rods will both loosen. I’m wondering if when I took the rocker assembly off of the bike, things weren’t quite lined up and I left a valve spring a little bit cocked. I ask because I don’t want to accidentally Ram the piston into an open valve.
Old Sep 14, 2021 | 10:03 AM
Max Headflow
Of you are worried about it, rock the crank a little forward or back to get the piston down say 1/2 inch. While doing so the lifters for that cylinder should not move and the ones on the other cylinder will.
I hope the difference is length was obvious. Maybe both are exhaust?
Another possibility is you have a stuck lifter.
Old Sep 14, 2021 | 10:27 AM
WyoEglide52
Stuck lifter! I bet that is it. Because the exhaust lifter bleeds down faster than the intake lifter and then when I tighten the rocker assembly just before torquing the bolts, the intake rod won’t spin and the exhaust one will. Good idea! Thanks.
Old Sep 14, 2021 | 01:16 PM
WyoEglide52
Another possibility is you have a stuck lifter.[/QUOTE]
I removed the two lifters and squeezed some 20/50w Mobil 1 into the hole until old oil came out of the other hole. I reassembled, lifters, push rod covers, push rods, rocker and breather assembly. Tightened all bolt but didn’t torque yet. Ate lunch for 30 minutes to let the lifters bleed down. Check push rods and both spin. I’ve read elsewhere that lifters that are empty of oil can collapse. I don’t think mine collapsed but that one was probably stuck. Thanks again! 😎
Old Sep 14, 2021 | 05:52 PM
memphisharley's Avatar
memphisharley
good deal...sounds like you have it sorted.
I find it easier to find TDC on each cylinder with a straw. the TC will blow that straw damn near to the top of my garage on compression stroke. then I stick it back in there and rock engine back and forth to make sure the piston is all the way up then adjust the pushrods. works fine the 4 times I've done this so take it with a half grain of salt. lol
95ci springer
Engine Mechanical Topics
Apr 5, 2014 12:10 PM
sugarplum247
Ironhead
20
Sep 20, 2012 07:52 AM
Frito Bandito
Ironhead
Feb 26, 2012 07:33 AM
Weed's Ironscoot
Ironhead
Jul 12, 2010 08:37 PM
96roadking
EVO
May 6, 2010 05:05 AM
