So, I think I'm effed.....debris in oil pan
Old Oct 19, 2021 | 04:30 PM
DeeRoe's Avatar
DeeRoe
Default So, I think I'm effed.....debris in oil pan
Not sure how the eff this happened. Went to do the simple task of changing oil (2019 FLHRXS). I always pull the drain plug first, and then loosen the dipstick to make sure the butterflies in the heads are ok. When I pulled the dipstick, about 1/4 of the O-ring on the dipstick was gone......the O-ring was still in place, but part of it went into the oil pan. I looked...couldn't see anything. I put the plug back in the pan and put in 2 quarts of oil, and then drained it again to see if it would come out. Even poked around in the drain plug with a pick to see if I could get it. No luck.
Should I roll the dice and hope it either stays in the bottom of the pan, to somehow gets chewed up in the gerotors and happily makes its way to the filter? Or do I have to pull the pan and fish it out?
Like I said....I think I'm effed......
why the hell does an easy job always turn into a major issue........
Old Oct 19, 2021 | 04:38 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It's not in the crankcase. It's in the oil bag that bolts to the bottom of the transmission. Lot of baffles and traps before actual oil pick up pulled by pump. If the oil pump does get it, it will be flatten like pork going thru a grinder making sausage. Then to the filter.
It will be never ever get past the filter.
I personally would not give it a second thought. That oil pump is extremely hardened steel.
If it gives you warm fuzzy fillings and the doom and gloom post follows, lift bike and drop the oil bag.
Old Oct 19, 2021 | 05:40 PM
Eric Von Zipper's Avatar
Eric Von Zipper
Suckin a screw into the intake is a killer, o-rings Id not worry about. This to will past
Old Oct 19, 2021 | 05:54 PM
Jackie Paper
DeeRoe.. one question about one thing in your post about one way pop-it valve vent system. They are similar what you see in a snorkel. They are open one way out when motor is running. Normal, shut. When you popped up dipstick, what did you think they did?
Old Oct 19, 2021 | 06:21 PM
DeeRoe's Avatar
DeeRoe
I guess the proper term is the oil separator that sits on top of the rockers. If this fails, ther is more than just a “mist” that comes out of the breather tubes into the intake. By checking this when I change my oil, I guess I’m just making sure they’re working correctly.
Old Oct 19, 2021 | 07:01 PM
Jackie Paper
There is no failing. One way out. High rpm or a worn out motor will loose a little oil control. What most see is when a Harley sets, it drains and looks bigger then it is from the pipe walls covered in oil. The intake is just atmosphere in. It won't pull actual liquid oil. Just a little mist in the vent gas.
The little bit of lubrication oil coming up thru the ring gaps is more then what goes in intake.
pontiac69
Apr 29, 2011 11:41 AM
Jags93
Jun 29, 2010 07:45 AM
don03
Jun 23, 2008 02:48 PM
ord sgt
Oil Archive (no new posts)
11
Oct 4, 2007 07:12 PM
broadwayjoe
May 18, 2007 04:04 AM
