What would you do? Cams and lifters.
Old Nov 1, 2021 | 05:10 PM
chopper_man's Avatar
chopper_man
Default What would you do? Cams and lifters.
Hey all,
2014 SGS, bikes got S&S 585 ez-starts, cam plate, lifters, quickie push rods, true duals with twin slash mufflers. Ness Big Sucker AC. Running a Thundermax. 25k on the bike, about 3k since I did the S&S kit.
Just bought the ScreaminEagle Stage 5 Tire Shredder kit for it and about to put it in.
https://shopbigskyharley.com/product...062d16d6&_ss=r
Kit comes with SE 259 cams, SE lifters and SE perfect fit push rods.
Thinking about just selling off the "extra" SE parts (the ones above) and keeping the S&S ones I already got.
What would you recomend? Any of them "better" than the S&S?
Thanks!
-Brian
Old Nov 2, 2021 | 05:16 AM
brownie4412's Avatar
brownie4412
Hey all,
Thanks!
-Brian
I would keep the S&S lifters for sure. As for the cams it really depends on what you want out of it. The 259 is very torquey but falls on it's its face fairly quickly. It also runs hot. At 10.2-1 there are tons of cam options available to you.
Old Nov 4, 2021 | 08:50 PM
Max Headflow's Avatar
Max Headflow
Not sure how you can say the 259 is a torquey cam when it has a wider LSA and 47 deg intake close. The 585 is only 45 deg. Only way it will run hot is if the bike ain't tuned. Canned map? Maybe.
TD will kill HP.
Old Nov 5, 2021 | 07:59 AM
brownie4412
TD will kill HP.
Yeah that’s my mistake. I got the 255 and 259 crossed up. The 255 is what came stock in my S. That is a a torquey cam. I can’t speak on the 259.
Old Nov 5, 2021 | 08:28 AM
rigidthumper's Avatar
rigidthumper
If you have V&H true duals, they will kill the horsepower- just too restrictive.
259 and the S&S 585s both work well closer to 10.5 static, but either require a good tune, with the 259 slightly better (3-5%) across the board.
The static CR of that kit is 10.2. Use a Cometic .030" head gasket instead of the HG that comes with the kit, and get it closer to 10.5. I'd stick with the S&S lifters, because that's a better product than the SE tappets.
custom_fatboy
Engine Mechanical Topics
May 21, 2014 12:12 PM
scasey
May 22, 2011 08:32 AM
2005 Roadking
Oct 24, 2010 08:57 AM
davlyo
Oct 26, 2009 05:19 PM
draycer
Exhaust System Topics
Aug 31, 2007 06:49 AM
