1340 Evo Will Not Start
Old Mar 12, 2022 | 05:02 PM
87softail's Avatar
87softail
1st Gear
Angry 1340 Evo Will Not Start
I have a 1987 , 1340 evo that will not start, both plugs have spark and are brand new. I have tried squirting petrol straight into cylinders but it still wont fire.
The bike has been converted to regular points instead of the standard ignition system and normally runs fine.
Any help to troubleshoot this problem would be much appreciated.
Old Mar 12, 2022 | 05:14 PM
Czracer's Avatar
Czracer
Default Check for compression
I would check to make sure you have compression, that would cause it not to start , especially if you have fuel and spark ,
Old Mar 13, 2022 | 06:17 PM
ConfuciusSay's Avatar
ConfuciusSay
Check the gap on your points.
Old Mar 14, 2022 | 12:48 AM
87softail's Avatar
87softail
1st Gear
Aby idea what gap it should be?
Old Mar 14, 2022 | 12:50 AM
87softail's Avatar
87softail
1st Gear
I have ordered a compression tester so will see how that goes, thanks
Old Mar 20, 2022 | 08:24 PM
87softail's Avatar
87softail
1st Gear
i have done a compression test and both cylinders were 30psi, seems a bit low to me, any thoughts?
Old Mar 20, 2022 | 08:29 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah, Top end rebuild..
Old Mar 20, 2022 | 08:42 PM
87softail's Avatar
87softail
1st Gear
the last time i rode it was fine, then it sat a few months, now i try to start it and nothing. Seems strange how top end could fail just sitting there
Old Mar 20, 2022 | 09:24 PM
Czracer's Avatar
Czracer
something is definitely not sealed up like it's suppose to be. If you have only 30 psi on the gauge , you either have rings not seating , or valves not closed all the way . Either way that engine needs to be torn down and inspected . There is no quick fix for this . Either some parts went bad, or workmanship was not done very well.
Old Mar 21, 2022 | 05:45 AM
98hotrodfatboy
That is strange.. What else did you do to it?? 30 psi is extremely low... 140-160 psi on a stock motor.. Carburetor wide open and battery fully charged???
