Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Welcome from Spartan Country, Michigan! I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips. Good Luck!!
Congratulations on your first post to HDF, welcome to the forum.
Probably not with all the modification and electronics involved. Why not buy a nice S&S crate engine, rebuild what you have or contact FuelMoto for their recommendation.
They are a site sponsor, have great customer service, and will steer you in the right direction.
Welcome to the forums from Middle of Nowhere!
You could always do a cap job (lift the gas cap, roll out old motorcycle with a check for $$$ thousands, and roll in the new bike, install cap in place).
