Nitrous kit
Old Apr 1, 2022 | 11:02 AM
hrdtail78's Avatar
hrdtail78
Understanding nitrous, and what it does is very important. All in all, since it was developed for aviation and short field take off, I believe it is a very safe way to add oxygen to cylinder fill. This extra oxygen requires more fuel. I got bikes out there tuned for nitrous on the street that have put 50- 60,000 miles on them. Never had a problem. I can't speak for others or how they set them up, but if you have problems. It will boil down to a couple of things. First you have no idea what you are doing and should step away. Some application aren't suited for nitrous at all. The other is people don't know what it is or what it actually does or how to best use it for their application. A 15 shot of nitrous and a 2 stage, 150 collective shot can not be treated the same. A 15 shot can be done on a stock ECU and the IAT if set correctly can deal with the extra fuel. The other is going to require a separate cal or a piggy back tuner to add the fuel and retard the ignition. A stand alone ECU that controls the solenoids directly is the best bet. How much more power are you looking for and what are you willing to do to achieve that safely?
Old Apr 1, 2022 | 03:32 PM
bustert's Avatar
bustert
delete, link not working
Old Apr 1, 2022 | 03:44 PM
TriGeezer's Avatar
TriGeezer
I’d probably supercharge first.
Old Apr 4, 2022 | 10:43 AM
slw210's Avatar
slw210
Why not ask in the appropriate forum?
Blowers/Turbos/Nitrous Oxide - Harley Davidson Forums (hdforums.com)
Johnny Goodlife
Aug 3, 2020 11:06 AM
VETERAN75
Jan 22, 2016 12:49 AM
ALPHA_MALE
Apr 19, 2009 10:15 AM
Cajun Fat Bob
Feb 29, 2008 11:10 PM
