Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looking to do a 107 set up on my 2016 street glide I know there are a lot of different packages out there but I think I have decided on One of two options
fuel Moto level b heads woods tw 999–6 cams 107 cylinders 10.8 compression , fat cat , 5.3 injectors, SE 58 mm throttle body
Or
send my heads to S&S for porting , s&s 635 cams s&s 107 cylinders 10.8 compression, fat cat, 5.3 injectors, SE 58 mm throttlebody
If you are happy with the CR575, stick with CR and look at the 630i. I am running the CR 595 in a 98" motor making 115/115 numbers; Wes knows how to grind these cams for a great combination of TQ and HP.
