Cam change question
Old Apr 4, 2022 | 09:42 PM
txphatboy's Avatar
txphatboy
Default Cam change question
Just swapped out a S&S 475 cam for a S&S 540 cam this past weekend. Started bike up and I got a lot of clatter. In my old TC, I got lifter noise after cam swap, but it cleared up quickly after a minute. I let the M8 idle for a couple minutes, but no change in noise. Pushrods are SE tapered adjusted to 20 flats. I used S&S recommended 18 flats for 24tpi PR and added two more flats. Are more flats needed for .540 lift?
i have seen some people say ride it 20-30 minutes and noise will clear, but I don’t want to ride it that much before tuning. I can adjust PR’s again if needed, but won’t have much opportunity before tune scheduled day after tomorrow. Any risk of harm during tune or negative effect on tune if PR’s do not quiet down and need adjusting later?
Old Apr 4, 2022 | 09:54 PM
rigidthumper's Avatar
rigidthumper
Did you check clearances?
Old Apr 4, 2022 | 09:57 PM
txphatboy's Avatar
txphatboy
Yes - SE CnC heads rated for .540 lift
Old Apr 5, 2022 | 08:09 AM
rigidthumper
'Rated for' assumes the assembler at the factory did his job properly (usually good, but never 100%).
If you have something like one of
these these
, you can pull a spark plug and see if there's any evidence of contact. (also handy for seeing crosshatch/oil/etc)
Old Apr 5, 2022 | 08:42 AM
jake24lt's Avatar
jake24lt
The size of the cam shouldn't make any difference in the push rod adjustment. I would most likely , redo the adjustment.If its rattling away after a few minutes, something is off.
TO34
Mar 8, 2012 09:04 PM
cruzmisl
Sep 17, 2011 04:12 PM
tripacer1
Exhaust System Topics
Sep 9, 2011 08:46 PM
Bad Disposition
Mar 8, 2009 03:15 PM
Fatboy931
16
Mar 24, 2008 02:32 PM
