Intake flutter avoidable?
Old Sep 17, 2011 | 02:41 PM
cruzmisl's Avatar
cruzmisl
Default Intake flutter avoidable?
Hi All,
After the cam swap I noticed more intake flutter between 1500-2500rpm. Its not objectionable just wondering if its avoidable or if it just comes with the territory.
Thanks,
Joe
Old Sep 17, 2011 | 02:58 PM
mkguitar's Avatar
mkguitar
not quite sure what intake flutter is- not familiar with that term.
I am guessing you are describing something that results from the cam timing and overlap.
mike
Old Sep 17, 2011 | 03:33 PM
cruzmisl's Avatar
cruzmisl
Yeah its basically a noise from the intake during that rpm. Hard to describe almost like a bubbling.
Old Sep 17, 2011 | 03:39 PM
hopperop's Avatar
hopperop
I hear what you're saying, I gave my girlfriend a cam job now she is making bubbly noises too.
Old Sep 17, 2011 | 03:49 PM
mkguitar's Avatar
mkguitar
with the change in cam timing overlap, you may be able to tune out the flutter with a change in exhaust tract length, diameter, restriction
or by changing the intake tract ( such as length)
what is likely happening at the rpm range is a wave coming back up the pipe, the exhaust and intake valves are both open, so that wave can travel all the way to intake.
in which case cylinder fill/ intake charge velocity would be affected resulting in reduced power
true duals by chance?
mike
mike
Old Sep 17, 2011 | 04:12 PM
cruzmisl's Avatar
cruzmisl
No its a Dragos 2 into 1. It has a 2.55" baffle which is big so maybe a smaller baffle would minimize it. Not that I would buy one just curious.
jmd897
Engine Mechanical Topics
14
Jun 14, 2019 11:27 AM
mr.precision
EVO
48
Apr 11, 2017 03:28 PM
ultraclassic53
Screamin Eagle CVO Models
Oct 31, 2012 07:45 AM
187
EVO
20
Jun 12, 2012 12:15 PM
lindnersreds
Apr 9, 2008 11:14 AM
