Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
There is a brace under the engine toward the rear. Somehow it got in there and was wedged between the brace and the engine/transmission. It was hard to see, I didn't find it until I stuck a screw driver in there and felt it. What a cluster!
Well after all that, I found it..... It was a freaking rock wedged in the back area of the engine. I originally looked for something like that but didn't see anything.... Oh well its fixed now.
Good news! I should have suggested that in my first post or at least down the line when we had elimnated everything else; I could have saved you so much time and anxiety. My brother had the same issue with his softail; drove us nuts. We were certain that the vibration was not a bottom end issue and checked everything else, i.e., fasteners, heat shields, motor/trans contact with the frame, etc., etc. We finally found a small rock wedged at the same place you found yours.
And I thought it was a freak thing. Guess I'll file this in the frontal files of the brain.
I don’t think I have that brace under my 2008 electric glide. Would you mind please taking a picture of where it was at. I’d really like to see it, because the more knowledge you have, the wiser you get. Thanks, i’m really glad you got it Figure it out….
I get it. That’s the frame crossmember I think and yes, my Electra glide does have that crossmember. Mines just a little bit different shape. Thanks for posting that picture, I appreciate you
I was thinking the same but assumed that if he'd replaced the swing arm rubbers, he would have noticed it..
I do find it odd that your brother had the same issue on a motor that is rigid mounted to the frame tho.
