Foot lbs or Pound ft = torque?
Old Apr 22, 2022 | 10:13 PM
  #61
IdahoHacker's Avatar
IdahoHacker
Originally Posted by Ed Ramberger
Lol! I'm making my own head hurt! I'm going back half a century! Luckily, this part of physics hasn't changed any.
Old Apr 22, 2022 | 10:51 PM
  #62
Max Headflow's Avatar
Max Headflow
Originally Posted by IdahoHacker
I don't believe that is correct. You're kinda mixing the two things. Lb-ft is torque, and torque has no rate, or time component. Torque is a force times a lever arm. There is no time involved.
Ft-lbs is work, and work also has no rate, or time component. You move a certain weight a certain distance, and work has been done. It doesn't matter how long it takes. Time has nothing to do with work.
Power most definitely has a rate or time component. The faster you do work, the more power. But, you don't: "Take ft-lbs and add rate, and it becomes the same thing, power." Ft-lbs is torque, not work, and you can't add time to torque, and torque has nothing to do with power.
Yeah, you are right.. I'll fall back more of a definition thing here..
Old Apr 22, 2022 | 10:56 PM
  #63
IdahoHacker
In another life, I'm a Rules of Golf tournament official. Trust me, in golf those "definitions" are reeeeeally important.
Old Apr 22, 2022 | 11:22 PM
  #64
Harley1004's Avatar
Harley1004
Yes they are reeeeeeally Important. Thank you IdahoHacker and thank you Mr. Ed.🇺🇸 S.A.E. class ***101***
Old Apr 23, 2022 | 12:18 AM
  #65
Harley1004's Avatar
Harley1004
I had a very respected Harley Davidson motorcycle engine builder/designer tell me that I was incorrect when I told him my Dyno Numbers. The end result of my build was 119 lb-ft of torque, and only 104 hp from my 103 in.ł twin cam.
Let me ask all of you this: when I hook up my 6 cylinder 375 hp Peterbilt to my 48 foot trailer and the trailer is loaded with 45,000 pounds of weight. How is it possible that a 375 hp motor will get me to 75 or 80 miles an hour pretty quickly with that much weight?
I have a v8 410hp pickup truck, if I hooked my pick up truck to my 48 foot trailer with 45,000 pounds on it,
I would probably never be able to get that loaded trailer up to 35/40 mph. And if that little truck could, it would probably take it an hour to get there. Hell, that’s 35 more horsepower in the little truck versus the big truck. I know One engine runs on diesel fuel, the other one runs on gasoline.: Diesel engines do make more lb-ft of torque than gasoline engines, however:
My Diesel engine puts out over 1500 lb-ft of torque. Regardless of what fuel is used, it is most certainly possible to make more torque then you do horsepower, no matter what type of fuel you explode or 🔥 burn.
5252 is the magical number in physics where Horsepower and torque MEET…S.A.E. But that doesn’t mean it’s the only number where those two Figures cross each other on a Dyno.
There is an engine builder on this forum that has said, “if you ain’t got torque, how much horsepower you’ve got reeeeeeally doesn*t matter! Personally, I couldn’t agree more!
Old Apr 23, 2022 | 12:53 AM
  #66
Harley1004's Avatar
Harley1004
Originally Posted by Paintslinger16
But where do you put the top after opening the bottle?
Funny lol☘️
Old Apr 23, 2022 | 07:47 AM
  #67
billgran's Avatar
billgran
The only time you see horsepower and torque lines cross at 5252rpm is if the graph uses the same scale for the horsepower axis and for the torque axis. If the scaling is not the same, then the lines cross at a different area.
The torque and HP must be scaled the same on the graph or they won't cross at 5252.
Old Apr 23, 2022 | 08:16 AM
  #68
Max Headflow
You did you measure the HP at the rear wheel? How meny speeds did each have in the tranny? What type of tranny. It's all about converting power to force at the rear wheel.
Why is that I can get my bobber off the faster than a GSXR 1000 but by the end of second gear the GSXR passes me?
Old Apr 23, 2022 | 08:21 AM
  #69
Uncle Larry's Avatar
Uncle Larry
This reminds me of hitting the wall versus going through the wall
Old Apr 23, 2022 | 08:26 AM
  #70
billgran's Avatar
billgran
