Top end big bore - compression not what it should be?
Old May 22, 2022 | 05:55 PM
Adam76's Avatar
Adam76
Originally Posted by fat00boy
What exhaust is actually on it?
It has the stock headers and the original old school screaming eagle slip ons. Very similar to the S&S tapered turbo slip ons.
I'm not too concerned about maximum power, just trying to figure out what could be causing a loss of compression.
Thanks
Old May 22, 2022 | 06:12 PM
Max Headflow's Avatar
Max Headflow
Thanks
What bike?
Old May 22, 2022 | 06:43 PM
Adam76's Avatar
Adam76
2002 Softail
Ness big sucker intake and DTT ignition.
Old May 23, 2022 | 11:44 AM
djl's Avatar
djl
For DJL.. They are 0.040 over 95 pistons from KB.. WFO larry got me some 3.915 pistons for my 02 RK.
10lbs off is fine. Don''t worry about it..
Thanks, was not aware but why? agree on the 10lbs.
Old May 23, 2022 | 12:03 PM
Max Headflow
Because KB does not make 3.938" pistons? The pistons are cheaper than Wisecos and pretty good quality. I know Larry has been bugging KB to make 98s but so far they haven't. (Maybe now?)
Old May 23, 2022 | 05:36 PM
Adam76's Avatar
Adam76
Thanks djl, you say not to worry about the 10 lbs. OK, but what if my thread title was - S&S 570 95" build lacks power? The only reason I checked ccp was because it just doesn't feel like it is making the tq/hp it should. It feels sluggish.
If I do indeed have only 190 psi, should I maybe consider a cam change to get the best out of this build? Maybe an tw-57 - like the old 37 cams with the extra lift?
Thanks
Old May 23, 2022 | 07:21 PM
jbarr1's Avatar
jbarr1
Possibilities of lack of power- exhaust, timing, sumping, clutch, jetting.
Old May 23, 2022 | 10:36 PM
harpwrench's Avatar
harpwrench
Slop in the crank sprocket can throw ccp off a lot if it’s retarding the cam. 100 hp is a pretty optimistic hp/ci goal with stock heads, and a B motor to boot. You’d honestly be lucky to make 100 hp with a 103 A engine and a good dyno tune, which is the other thing that you don’t seem to have. Can easily lose 10+ hp with lack of tuning.
Old May 24, 2022 | 01:20 AM
Adam76's Avatar
Adam76
OK fair call.
without proper dyno tuning I can't expect too much.
I guess the only question I have left is whether to leave the 570 cams in with a little less compression than they'd like, or swap them out for something that is optimised at 10:1 comp might give me more usable torque.
I was considering the Andrews 57 (same as 37 with more lift)....
Thanks
Old May 24, 2022 | 08:26 AM
Max Headflow
OK fair call.
Thanks
Doing that isn't going to give you more power. Low end will pick up some..
