Bottom end only
Old Aug 21, 2022 | 05:53 PM
vikemaster's Avatar
vikemaster
Default Bottom end only
I have 80 ci Evo with only 24 k miles. Flywheels got out of true a bit, so I am shipping the bottom end off to get trued and have new bearings put in etc. my question is, would it be ok, providing the cylinders and rings are in good shape to put them back on
and use them as is or is it standard procedure to hone cylinders and install new rings whenever you
Have things apart. I have other bikes I ride so it will probably be 5 more years before the motor reaches 50 k. It’s my around town bike. Appreciate any input. Thanks
Old Aug 22, 2022 | 08:13 AM
t150vej's Avatar
t150vej
With those few miles, hone the cylinders with a 240 grit ball flex hone. New rings, Hastings 2M-6164-std should be all it would need.
Use OEM gaskets. Contrary to popular belief, the current style cylinder base gaskets do not leak and the rocker cover gaskets fit better than anything out there.
Old Aug 23, 2022 | 08:42 AM
vikemaster's Avatar
vikemaster
Sounds reasonable. thanks for your reply !
Old Aug 23, 2022 | 08:49 AM
t150vej's Avatar
t150vej
On your other thread, it was mentioned to remove the cylinders, leaving the pistons in place. On a healthy top end, that is totally acceptable and common practice when replacing base gaskets. But I always hone and replace rings if the pistons are removed from a cylinder that's already been run past break-in.
Don't re-use the removed wrist pin clips if you go that route, replace with new.
Old Aug 23, 2022 | 09:44 AM
tdrglide's Avatar
tdrglide
Definitely agree on the new wrist pin clips.
Curious, how do you know the flywheel needs to be trued
Old Aug 24, 2022 | 09:25 AM
vikemaster's Avatar
vikemaster
thanks ! I will make sure I replace the clips. As to your question about how I know it is out of true.
My Dyna was smooth as silk. The rev limiter was mistakenly set too high on my Dyna 2000 ign module
and the rpm’s ran too high while out riding and felt a difference immediately. It’s not extreme but I can feel the difference and I want that smooth balanced feel back
Old Aug 24, 2022 | 09:31 AM
vikemaster's Avatar
vikemaster
Thanks for all your replies and good advice
Old Aug 24, 2022 | 05:15 PM
tdrglide's Avatar
tdrglide
Did you do a compression test. High rpms may have had a little valve float. Maybe bent a valve just enough to loose compression in one cylinder. If compression uneven by more than 10% do a leak down test
Old Aug 25, 2022 | 09:30 AM
vikemaster's Avatar
vikemaster
Thanks, I’ll do a compression check in the next few days and let you know what I find. It just really feels like something is slightly out of balance. The motor’s running real good and very strong . Spark plug electrodes look great.
But it definitely would be a good idea to do that simple test to eliminate that possibility before I pull the whole motor out .Thanks!
Old Aug 25, 2022 | 10:34 AM
t150vej's Avatar
t150vej
I agree you should ride it and check the simple things before diving into a big $$ project on hopes of eliminating a vibration. There's a long list of things that can cause vibration, like loose engine mounts/bolts, primary chain adjustment, exhaust loose or touching somewhere it shouldn't or belt adjustment just to name a few.
Since it's an Evo, start another thread in that section with the model and year and any physical modifications (exhaust, etc) There's a lot of guys there who can offer more specific places to look/check if we know what you're riding.
https://www.hdforums.com/forum/evo-classic-models-84/
