Bottom end only
Old Aug 26, 2022 | 09:12 AM
vikemaster's Avatar
vikemaster
Originally Posted by t150vej
I agree you should ride it and check the simple things before diving into a big $$ project on hopes of eliminating a vibration. There's a long list of things that can cause vibration, like loose engine mounts/bolts, primary chain adjustment, exhaust loose or touching somewhere it shouldn't or belt adjustment just to name a few.
Since it's an Evo, start another thread in that section with the model and year and any physical modifications (exhaust, etc) There's a lot of guys there who can offer more specific places to look/check if we know what you're riding.
https://www.hdforums.com/forum/evo-classic-models-84/
Thanks for that suggestion. I am on top of adjustments and things being secured and torqued properly.( although I messed up on the rpm setting which caused this entire problem lol) Since this vibration started I have gone over everything and replaced the motor mounts recently as well. Drive Belt and primary chain have been double checked as well. Tires balanced. I am really confident that it is the flywheels so if the compression checks out
thats the route I will take. I appreciate the additional suggestions And realize that when forum members comment on a post they have no Idea if the person asking for help is a Moron or someone that has it somewhat together. I am in the have it somewhat together category. Since I have checked just about everything I was really posting to get input on whether to change the rings and hone or not .
But I appreciate all of everyone’s input and suggestions .
Old Aug 26, 2022 | 05:30 PM
vikemaster's Avatar
vikemaster
Compression results 149 psi front cylinder 146 psi rear cylinder
Old Aug 26, 2022 | 07:36 PM
tdrglide's Avatar
tdrglide
Okay then. Sounds good
One thing I would recommend, if it were mine, since it will already be apart, is using a thinner head gasket when reassembling. 0.030 or 0.036. Available through Cometic or James. A little bump in compression will give a little more pep
Old Aug 27, 2022 | 09:42 AM
vikemaster's Avatar
vikemaster
thanks tdrglide , I will get the thinner James head gaskets separately and make sure they are within that thickness range.
who doesn’t want a little more pep! Since you mentioned gaskets, I was going to buy a complete James gasket set because I am going to need
all new gadgets when I reassemble and have always had good luck with James gaskets. Have you used a James complete set and if so would you use it again?
Old Aug 27, 2022 | 01:43 PM
vikemaster's Avatar
vikemaster
I have an update on the compression. Went out and picked up a new thread in type compression tester. Mine was busted so I used my old push and hold in type when I took it initially and it was lower than I thought it would be since I have
edelbrock heads (which I love by the way despite their rarity ) which prompted me to go get a new comp.tester So with the new tester I got 166 in the front and 170 in the rear. Plenty of compression and
well under the 10% variance.
My evo can hold its head high.
Its got a little juice!
vikemaster
Engine Mechanical Topics
Aug 22, 2022 09:22 AM
1340fxrt
EVO
Mar 14, 2022 12:33 PM
rewstr
EVO
Jul 10, 2010 06:23 PM
MGN54
EVO
May 1, 2010 09:29 AM
ShovelHeadKid
May 21, 2008 03:54 PM
