Bottom end only?
Old Aug 21, 2022 | 01:01 PM
vikemaster's Avatar
vikemaster
Default Bottom end only?
I have an 80 ci EVO with only 24k miles on it
runs great but flywheels are slightly out of
true. I miss that smooth feeling my FXD
had so I am sending bottom end in
in to get trued and new bearings etc .My question is,
is it ok to touch cylinders up with a hone
and leave the existing rings on ? I have other
bikes I ride as well and it will probably take
me 5 years to put another 25 k on this bike.
appreciate any input. Thanks
Old Aug 21, 2022 | 01:25 PM
tdrglide's Avatar
tdrglide
You can pull cylinders and pistons without completely removing pistons from cylinders. Pull cylinders up enough to access pin circlip leaving rings still inside. Remove circlip and pin, keep pistons in cylinders.
If for some reason piston rings come out, put them back in. Honing not necessary unless replacing rings. More likely to create problems on low mileage motor
Old Aug 22, 2022 | 09:22 AM
vikemaster's Avatar
vikemaster
Perfect ! Thanks , that’s exactly what I will do.
I really appreciate the intelligent and practical reply.
1340fxrt
EVO
Mar 14, 2022 12:33 PM
rewstr
EVO
Jul 10, 2010 06:23 PM
MGN54
EVO
May 1, 2010 09:29 AM
Hagar the Horrible
EVO
31
Dec 22, 2008 12:19 AM
JDixon
Sep 19, 2008 09:09 AM
