Bolt Pattern
Old Aug 30, 2022 | 12:11 PM
roadtoad72's Avatar
roadtoad72
Stage IV
Default Bolt Pattern
Is the bolt pattern the same on all twin cam motors?
I have a 2002 twin cam 88.
Old Aug 30, 2022 | 12:48 PM
tdrglide's Avatar
tdrglide
Which bolts?
Old Aug 30, 2022 | 12:57 PM
rigidthumper's Avatar
rigidthumper
Head bolt? Yes
Cam cover? Yes
Intake manifold- changed in 2006
Case to primary? No
Old Aug 30, 2022 | 01:00 PM
roadtoad72's Avatar
roadtoad72
Stage IV
The cylinder head bolt pattern
Old Aug 30, 2022 | 01:02 PM
roadtoad72's Avatar
roadtoad72
Stage IV
I want to get a 4.25" Big bore kit
with a 5/8" stroker crank
Old Aug 30, 2022 | 01:09 PM
rigidthumper
Stock TC bolt pattern leaves too little area to seal well long term. 4.125" works better. S&S ( & others) make special purpose cases & flywheels that are made for huge bore ( 4.25-4.5") engines. Special components (custom exhaust, intake manifold, extra length pinion shaft right side flywheels, etc,) are needed to keep everything aligned.
Old Aug 30, 2022 | 02:02 PM
roadtoad72's Avatar
roadtoad72
Stage IV
Thank you
CSMHOG
Forum Issues
18
Jan 28, 2019 09:17 AM
