Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Thinking of going with Kibblewhite manganese guides. Any reason to ball hone after reaming? The AV&V reamer is considerably more expensive than the Kibblewhite, anyone have an idea why?
You really don't ball hone a guide, you brush hone.. Whether it's necessary is open, I'd look at how good a new valve slides into the guide. A little tight or rough feeling, use the brush or even use a full blown sunnen hone. A good ream job will likely not need any more steps if you have the right size..
The big issue is that for the manganese guides, you need a carbide reamer. If the kibblewhite guide you are looking at is high speed steel get the AVnV. IIRC kibblewhite might sell a cheaper carbide reamer. If not AVnV.. There are cheaper quality carbide reamers out there if you want to look.
Thank you for your help on this. You cleared my head!
