Cam plate install issue
Old Jan 16, 2023 | 07:27 AM
lloyd123's Avatar
lloyd123
Default Cam plate install issue
I am installing new cams in my 103. When reinstalling cam plate in case all feels good but cam plate does not go all the way in.It is about 1/4 away from being all the way to the case. Anybody have any ideas on what could be wrong?? Lifters are removed so its not hanging on them.
Old Jan 16, 2023 | 08:57 AM
Rocking_it's Avatar
Rocking_it
Had same issue when replacing my cams. I had wife gently push against plate while I turned rear wheel. Fell right into place.
Old Jan 16, 2023 | 09:13 AM
Weeboy1's Avatar
Weeboy1
Ensure only one oil pump O-ring. Easy to forget to remove case side and the add another to the plate. Otherwise as said a slight rotation forward or back on the rear wheel should get her in.
Old Jan 16, 2023 | 09:53 AM
Max Headflow's Avatar
Max Headflow
Did you remove the oil pump from the cam plate? If not you will likely have to rotate the crank until the gerotor lines up with the flat on the crank. Hopefully you replaced the inner oil pump O ring.
Old Jan 17, 2023 | 07:36 AM
lloyd123's Avatar
lloyd123
Thanks brothers I was able to get it by having a friend move rear wheel just like you said
Uncleporkchop
Nov 4, 2021 06:44 PM
WyoEglide52
Engine Mechanical Topics
11
Sep 5, 2021 02:54 PM
Sandcrab
Oct 1, 2020 11:32 AM
Kenjr
Exhaust System Topics
Nov 4, 2011 03:49 PM
dawg
Oct 10, 2006 06:33 PM
