Timken conversion
Old Jul 4, 2023 | 12:47 PM
Frill452's Avatar
Frill452
Stage III
Originally Posted by Thebikerpiper
Thank you for the reply, but again: I'm looking to get a specific question answered, which you too failed to do in your response.
The question is:
In installing a timken bearing conversion, does the left side bore require trueing to bring it in proper tolerance of the right side?
Hi Thebikerpiper! I have done the Timken converts by Jims tool and insert. You do it from the old bore in the left crankcase. No need for boring and truing of the crankcase. Sincerely Peder.
Old Jul 4, 2023 | 01:26 PM
ntraindavefl's Avatar
ntraindavefl
Hello all,
Before responding please, ask yourself, "does my response include a fact based answer to the specific question asked?" If the answer to that question is no, please refrain from commenting. Opinions are great things, but that's not what I'm looking for today. If you don't know how to help, start with staying out of the way.
I was planning on doing a timken conversion on my 09' FLHTCU. Another rider I was speaking to said that when Harley went to the left side roller bearing they also began having the left and right case halves manufactured separately and as a result the left side bore is often not true and needs trued to the right side before the conversion can be done.
I hadn't heard this mentioned in the YouTube videos I watched or a few articles I read. So, naturally I wanted to check with some other folks on this.
Thank you for the feedback
bikerpiper
This guys a real piece. Preemptively scolds everyone, then never actually asks a question.
Old Jul 4, 2023 | 01:46 PM
djl's Avatar
djl
Hello all,
bikerpiper
If the OP had left out the first paragraph and asked the direct question that you evenually asked in a later post would have been a much better way to solicit specific replies. Why **** everyone off right from the start?
John Dahmer at Darkhours can answer the OPs question but I don't think the answer is a clean yes/no and at the end of the day, the OP will have to make the decision based on the build plan which the OP has not provided..
Old Jul 4, 2023 | 01:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Big shot, setting guidelines on how people should help him.
John Dahmer can answer the question (whatever it is) as long as he follows the OP`s strict guidelines for answering.
Old Jul 4, 2023 | 02:40 PM
TwiZted Biker's Avatar
TwiZted Biker
FYI for everybody in here, Harley went away from the Timken bearing on the cranks as cost and time saving move on the production line. The current floating pressed together flywheel assemblies can be done by a fully automated process whereas the superior timken assembly takes more time and live bodies to assemble and check correctly. That said the technology for very accurate automated machining and assembly processes allow for this.
That's the bottom line.
As to the original posters issues, the crankcases are are line bored and honed as matched sets regardless of when or where the individual parts were made.
Old Jul 4, 2023 | 06:24 PM
Rounders's Avatar
Rounders
I have wondered if this is some thing I want to do on my 2007. Other than stage 1 it is stock, not sure I want to go to much farther. This was a big topic years ago.
Old Jul 5, 2023 | 01:19 AM
Frill452's Avatar
Frill452
Stage III
Hello all,
bikerpiper
Sorry if my quote where not satisfactory.
i overhauled an 2006 engine. And that engine run great after the timken conversion. The flywheel set is of S&S 4 3/8 stroke. Everything true from left to right.
I am sorry I didnt now they changed the manufacturing later. Greetings Peder
Old Jul 5, 2023 | 06:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The flywheel assembly was the failure point on the TC engines, not the left side (non tapered) roller bearings.
How many posts have we seen in regard to failed left side roller bearings?
Old Jul 5, 2023 | 06:42 AM
Rounders's Avatar
Rounders
What is responsible for run out? Crank or bearing? Seems run out is one of the issues with newer engines.
Old Jul 5, 2023 | 07:34 AM
TwiZted Biker
Excess runout is the result of the flywheels scissoring, the pressed in crankpin relies on interference fit only hold both halves of the wheel assemblies true. Poor design and very prone to allowing the wheels to move.
