Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Thanks a lot, Sir. Yes, you are perfectly right about the method of feeling the blow on the finger, but at that time I had not installed the push rods and the valves would have then been closed also on TDC overlap. And then the TDC:s would have blown air both of them.
Even with the pushrods out find tdc and then look at the lifters. If they are at the same height you're tdc compression. If the intake is a little higher you aren't, roll it over one more time.
Thought I would update my threads. Good news so far. Bike runs great and I measured 190 PSI (Cold Cranking Compression at sea level) on both cylinders. This means 9.2:1 corrected compression, which is very satisfying.
I calculated with BigBoyz 186 PSI and 9.0:1, so I got a little more :-)
Thank you all for good advices and teaching. Without this forum I would never been able to make this build.
Can I jump in here and ask for someone to give me a plain English definition/explanation of what "overlap" means? Thx.
Overlap is the point where the exhaust valve just closes and the intake starts to open. This assumes you're turning the crank in the direction it would be turning if the engine was running.
More succinctly, overlap is the distance of crank rotation from when the intake opens to when the exhaust closes typically as piston reaches top dead center on the exhaust stroke and starts the intake stroke. It's typically measured in degrees of crank rotation at some small specified lift of the lifter.
I thought he was asking about finding overlap on one cylinder to adjust the push rods on the other. My Cathouse slang may not apply to Harley Davidson products.
