Sportster 1200 sputtering at low throttle
Old May 24, 2023 | 09:19 PM
ZKG's Avatar
ZKG
6th Gear
Default Sportster 1200 sputtering at low throttle
The problem: The bike functions completely normal when cold and warmed up with choke off. Once the bike gets more temperature and heat soaking it's way throughout the bike it will sputter or stall when giving low throttle. It will idle fine, it will ride fine if you can give it enough fuel to get past low throttle and get the rpm's up. https://www.youtube.com/shorts/bqin1ljYlyw
I've been digging into this problem a fair bit and I've concluded that it's unlikely a fuel delivery issue. The CV carb looks clean, the fuel filter looks clean and there isn't any apparent disruption in fuel. I replaced the ignition coil, plug wires and plugs hoping it was a bad coil; it was not. I'm trying to think of how heat could be causing a failure. I was thinking maybe however unlikely that it's bad rings causing too much friction for the engine to rotate at low rpm but I'm not getting excess smoke and it idles fine at low rpm. Not sure where to go next.
My next thought is:
1) Something may be malfunctioning in the carburetor where fitment changes when hot, maybe atomizing is being affected.
2) There's another loss of ignition elsewhere.
3) Loss of compression or vacuum somewhere that worsens as the seals heat up. I did try to induce an rpm surge spraying carb clean around the exterior of the carb near the gaskets, no surging.
Old May 25, 2023 | 11:18 AM
Harley1004's Avatar
Harley1004
Wow. If that is not coming out of the head from the head gasket, and it is actually coming out of the spark plug hole, which seems kind of unlikely, but if it is coming out the spark plug hole, I don’t even know how that engine is running.
Hey Max,Dan, have you ever seen that much oil coming out of a spark plug hole cause I haven’t. Seriously, I think you have a head gasket problem, cracked head, I pray you sure you get it figured out. I’m watching wanting to learn.
Old May 25, 2023 | 11:37 PM
ZKG's Avatar
ZKG
6th Gear
I'm not sure what you're pointing out. The spark plugs are on the other side and all my gaskets in the engine are good. A cracked cylinder would be catastrophically noticeable and not likely since I've ran this multiple times with this low throttle issue. No fuel in the oil, no blow-by, no ring smoke or metal smell. No metal in the oil. Any oil residue on that side of the bike is from the breather.
Old May 26, 2023 | 07:12 AM
bustert's Avatar
bustert
looking and being are two diff animals.
pilot circuit
transfer ports
accel circuit.
lift diaphragm
put some inline spark testers on to see if ign is dropping out, doubt it but never say never.
Old May 26, 2023 | 09:24 AM
cycleman11's Avatar
cycleman11
You have a stumble, hesitation or bog, whatever you want to call it. It happens at a transfer point in the fuel delivery system. For example: going from idle to 1/8 throttle which is primarily controlled by the mixture screw. The pilot jet provides fuel for this circuit.
So my view from watching your video your problem is just off idle. You often have to play a bit with the idle screw and the mixture screw as too much opening of the throttle plate ( idle screw ) opens the transfer ports on the bottom of the carb. You want to have as few of these open as possible. So the first thing I would do is try adjusting the mixture screw.
I have no idea what jetting you have in the bike, but it isn't going to be easy to eliminate your problem with those short pipes.
Old May 26, 2023 | 10:46 AM
jbarr1's Avatar
jbarr1
^^^^^^this!!!!^^^^^^
Old May 29, 2023 | 12:19 AM
ZKG's Avatar
ZKG
6th Gear
I would agree with you if the problem was persistent and immediate but it runs completely fine when cold/warming up but only when the bike is heat soaked the issue comes around. We've tried adjusting idle without change, and the bike has run how it is without issue for 4 years with head pipes and only now something has changed.
Old May 29, 2023 | 09:23 AM
cycleman11's Avatar
cycleman11
A warm engine requires less fuel than a cold engine. So it could be at operating temps it is running too rich or loading up on fuel. Not sure what pilot jet you have in the carb. If you haven't changed anything then it could be something as simple as a piece of dirt in the wrong place. Also vacuum leaks can cause erratic behaviour, but they are easily diagnosed at idle.
The area where you have the stumble is just off idle so you have to work on the areas that affect that portion of the carbs circuits. Namely the pilot jet and mixture screw. Nothing else carb related is actually involved at that point.
Old May 29, 2023 | 12:30 PM
Yankee Dog's Avatar
Yankee Dog
You did not mention intake manifold seal replacement. Leaky (old) manifold seals can do exactly what you describe... As the cylinders heat up they "grow" in length. When they grow in length, the seals lose their seal. They get hard with use (heat cycles) and time. Consider replacing. Make sure manifold is properly positioned when installing. Some air filter mounts will "pull the carb and manifold out of alignment and you will never know it unless you really look closely for it.
Old May 29, 2023 | 10:54 PM
ZKG's Avatar
ZKG
6th Gear
The bike will run normal when warm and choke is off, all throttle positions, highways, totally normal, only after heat has worked itself through will it begin to struggle. The one comment about a manifold leak might be the issue or a vacuum leaks elsewhere, thank you.
