89 Softail Springer starts and dies
Old Jun 21, 2023 | 05:41 PM
Malzero's Avatar
Malzero
Stage II
Default 89 Softail Springer starts and dies
I have a 89 softail 1340 that will start easily run for 10-45 seconds then dies, like I turn off the ignition switch. I was going to go on a ride fired it up it died and I continued this pattern for 30 mins or so and gave up. and now I'm here. Anyone have any ideas what could be causing this?
Old Jun 21, 2023 | 05:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What type carburetor?
What ignition system?
Old Jun 21, 2023 | 07:47 PM
Malzero's Avatar
Malzero
Stage II
Carb is stock. Unsure of the ignition
Old Jun 21, 2023 | 09:26 PM
Since 1968's Avatar
Since 1968
One thing that comes to mind is your carb is fuel starved. It starts up fine, the bowl runs dry and you're down. The bowl slowly fills and you can try again. You could undo the fuel line from the carb and check if you have free flowing gas. If not, you could look for obstructions.
Old Jul 2, 2023 | 09:16 AM
cgmartine's Avatar
cgmartine
Don't disregard the ignition switch. I had an identical problem with my 2000 Heritage Springer.
Old Jul 2, 2023 | 10:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
@Malzero Well, you could look and find out...
You are looking for help, aren`t you?
Old Jul 2, 2023 | 10:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted
Gwr
Twin Cam Motors
May 28, 2020 03:05 PM
MRJAYPEE
Motorcycles For Sale
May 27, 2015 06:11 PM
Dogs of war
Mar 18, 2008 07:14 AM
