Which cam?
Old Jul 24, 2023 | 08:40 PM
topcat1st's Avatar
topcat1st
Default Which cam?
Bike is 2014 Flhtk twin cooled 103 engine with stage1AC, street port heads with 82cc chambers, .030 head gasket pistons down in bore .008, power vision tuner with target tune with wide band sensors, fuel moto head pipe no converter and super trap disc mufflers.I am trying to decide which cam to use either Andrews 54h, T-man torqster or a Cyclerama 570 as I have all three,all responses appreciated
Old Jul 25, 2023 | 02:53 PM
djl's Avatar
djl
I am a Cyclerama fan; running the CR595 in my current 98" configuration. It would have to be the 570II for me.
Old Jul 25, 2023 | 05:56 PM
60Gunner's Avatar
60Gunner
I'm too lazy to do the math right now on what your compression is with 82cc chambers in a 103 but the 3 cams you listed vary greatly from 32° IVC for the 570-2 to 37° IVC for the Tman 555 to 42° IVC for the 54H.
OK. Ran the numbers. A 37° IVC would put your ccp around 201psi and a 32° IVC around 207psi and a 42° IVC around 195psi. All doable but with a good tune.
I like my Tman 590PS2. So ill throw the Tman 580PS with an IVC of 39° ..580 lift and a ccp of 200psi in as my vote.
Old Jul 25, 2023 | 06:17 PM
Ohio HD's Avatar
Ohio HD
Based on what you say as far as motor specs, and the three cams you have, I'd suggest the Andrews or the T-Man. They'll keep the corrected compression reasonable, where as the CR 570 will be near 9.7:1 corrected. I assume you want a no PMS setup, so keeping the corrected compression Andrews 9.3:1 - T-Man 9.5:1 is in your favor. The T-Man would probably get the nod
All three can be tuned successfully, but the slightly lower compression will allow poorer quality fuel, and a cooler running motor. If performance is your goal, and not cruising, then use the CR 570.
Old Jul 25, 2023 | 06:32 PM
djl's Avatar
djl
Not to start a compression debate but I run the CR595 at 10.2 corrected with no issues. I used to think that 9.6 corrected was pushing the envelope but not these days. Many are running much higher compression without issues. I am prettey sure that the CR 570, with a good tune, will out perform the Andrews 54 and the TMan "torkster" 555 but that's JMHO.
Old Jul 25, 2023 | 06:42 PM
Ohio HD's Avatar
Ohio HD
I don't consider what I said as pushing the envelope or not pushing the envelope. Simply he didn't state what his goals are, fuel availability, etc. Motors with less compression tend to run cooler, if that matters to him. You might note that I said if performance was his goal, he might use the CR 570.
Old Jul 25, 2023 | 07:27 PM
60Gunner's Avatar
60Gunner
I agree about compression however he is talking the 570-2. Not the. 570. With a 32° IVC the 570-2 will die off too early to make any real hp.
Not the same head work but there was some. Its not a hp cam.
https://www.roadglide.org/threads/20...040-hg.374341/
Old Jul 26, 2023 | 09:22 AM
djl's Avatar
djl
Originally Posted by 60Gunner
I agree about compression however he is talking the 570-2. Not the. 570. With a 32° IVC the 570-2 will die off too early to make any real hp.​​​​​​
Read the OP again, he is referring to the 570, not the 570II; just to clear that up. I don't think the 570 is available; replaced by the 570-2.
Can't compare the sheet you posted with the OPs configuration; much less compression. I did not claim that the 570II was a HP cam. You know that I am a torque guy and, as evidenced by the sheet you posted, the 570II will make tractor torque, especially with the higher compression and, IMHO, be much more fun to ride which is why I would run that cam over the others and why I said it would out perform the others. I don't need no stinking HP when I have 100+TQ on tap wherever the throttle is..
Old Jul 26, 2023 | 10:49 AM
user 7209823083's Avatar
user 7209823083
Well, 100 ft-lb at 3000 rpm is exactly twice as fun as 100 ft-lb at 1500 rpm. And at 6000 rpm those 100 ft-lb would be super fun.
If only there was a way to express both torque and rpm with one single number.. hmm
Old Jul 26, 2023 | 05:07 PM
topcat1st's Avatar
topcat1st
Im the OP. the cam is a 570cycle rama and not the 570-2. I had a T man 555 in the bike and decided to try the 570 It does come on quick with a lot of torque on botttom end but it ran out faster than the 555. The reason Im pulling the 570 is because of cam noise from the quick ramps and short duration. another guy had the same problem with his 570. I have but have never run a 54h cam so Im thinking about trying it. Andrews cam recommended it for my engine , tell me what you think.
