Which cam?
Old Jul 26, 2023 | 05:25 PM
user 7209823083's Avatar
user 7209823083
Originally Posted by topcat1st
Im the OP. the cam is a 570cycle rama and not the 570-2. I had a T man 555 in the bike and decided to try the 570 It does come on quick with a lot of torque on botttom end but it ran out faster than the 555. The reason Im pulling the 570 is because of cam noise from the quick ramps and short duration. another guy had the same problem with his 570. I have but have never run a 54h cam so Im thinking about trying it. Andrews cam recommended it for my engine , tell me what you think.
I really don't know which cam would work best in your bike, the only thing that comes to mind is the "camshaft shootout" that fuel moto have on their website, with Dyno charts for a number of cams using a 103 TC as test engine. Even if your bike has a bit different setup with higher compression and ported heads there might be some useful information.
My point here was that in these discussions people tend to think that torque and power are somehow independent properties, like "I prefer torque over power..", which is a misunderstanding of the physics involved.
There is really no point in having curves for both power and torque in a Dyno chart, they carry exactly the same information and each one of them can be constructed from the other one.
But his is off topic, I apologize for sabotaging your thread.
Old Jul 26, 2023 | 05:46 PM
shineola's Avatar
shineola
Do yourself a favor and wander over to HTT website, click on Dino runs try page 5 from December third 2017 started by Ancient. This just happens to be one of my favorite 103 Dyno builds that I have seen and I am also a big fan of the exhaust pipe which not a lot of people are. I think the components you’re speaking of may help you with some of your answers to which Cam to go with. I like the T-man
Old Jul 26, 2023 | 06:23 PM
60Gunner's Avatar
60Gunner
Looks just like my torque curve. The same guy set up my heads. He will tell you the Tman 580 in this case. I'd put money on jt.
Old Jul 26, 2023 | 10:17 PM
PureHybrid's Avatar
PureHybrid
Who's street port? 82cc should get you over 10:1 even with the pistons -.008". What are the specs of this CR570? I wouldn't be afraid to run that Tman 555 either, the heads should make it still pull decent on top
Old Jul 27, 2023 | 09:24 AM
harpwrench's Avatar
harpwrench
The first CR570 was 14/32 intake and 49/3 exhaust
I would try the 54 first, then try it 4 degrees advanced for fun. You’ll probably know immediately if you like it better or not. I would want a full sized crossover tube if it doesn’t have one, and working with the disc count is worth the effort. I would get some longer screws and extra discs, and have always had better response with closed end caps. Not enough discs kills mid-upper power a lot. I would guess around 20-25 discs per side and I like a couple more on the left on both my bikes.
Old Aug 5, 2023 | 09:03 AM
topcat1st's Avatar
topcat1st
I’ve installed the Tman 555 torqster, I am using Smith brother easy install pushrods and I am waiting on a set of there pushrod tubes for there pushrods. I installed a set of Vulcan rocker arm supports with shaft locks and new S&S precision lifters. I checked my pińion runout and have .0025 total, pleased with that.
Old Aug 5, 2023 | 07:31 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Aug 12, 2023 | 01:59 PM
topcat1st's Avatar
topcat1st
Default Which cam
Engine back together ,started immediately no lifter noise set lifter preload at .140, took it for a ride very quiet. Waiting to get it tuned. Idles at 1050 rpm by Power Vision. Pulls real good thru all gears. Im Happy
DynaMike8686
Twin Cam Motors
21
Jul 26, 2022 01:14 PM
fuelmoto
Feb 15, 2013 02:51 PM
DirtNap
Apr 29, 2011 11:41 AM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
Oct 30, 2010 08:46 AM
2005flstfi
Exhaust System Topics
Oct 20, 2006 12:22 PM
