engine dying
Old Aug 6, 2023 | 03:25 PM
FOCI's Avatar
FOCI
Default engine dying
so i have a 2014 dyna lowrider we where out on a long ride about 100 miles we were 50 miles out on way back coming up to a stop light so i was slowing down and the bike just stop running. got it running again came up on some curves so i was slowing down and it died again happened about 4 times but it started up again took it to the dealership checked out they could find nothing wrong any thoughts ?
Old Aug 6, 2023 | 03:29 PM
Y2K's Avatar
Y2K
Make sure your battery terminals are clean and tight,maybe run some fuel injector cleaner through it.
Make sure your gas tank is venting like it should.
Old Aug 6, 2023 | 05:51 PM
CoolBreeze3646's Avatar
CoolBreeze3646
When was the last time you had your fuel filter #4 and fuel pump inlet sock #20 replaced?
Bike is 9 years old. How many miles on the bike.
Old Aug 6, 2023 | 06:41 PM
FOCI's Avatar
FOCI
17 thousand miles
Old Aug 6, 2023 | 07:13 PM
golfblues's Avatar
golfblues
I had the same problem on my 06 Softail and had to replace the throttle position sensor and all has been good since...part #10
Old Aug 6, 2023 | 08:17 PM
memphisharley's Avatar
memphisharley
any codes
Old Aug 7, 2023 | 08:49 AM
djl's Avatar
djl
Clean the IAC port and motor and reset the IAC. Do not use carb or brake cleaner; mass air flow sensor cleaner only. Google for "how to" clean IAC and reset procedure; lots of info available. Maybe another forum member has the procedure handy and can post it; very straight forward, quick and simple.
Also clean the speed sensor. Do the easy stuff first.
Old Aug 8, 2023 | 08:24 AM
bustert's Avatar
bustert
had this to happen after hard run smoking a couple of cagers. turn out to be the spark plugs on front cyl. only happened on coast down when the plugs went cold, fortunately i was only a couple of miles from home. if i would have had single plugs per cyl it probably would have turned out worst.
Old Aug 8, 2023 | 11:29 AM
Rounders's Avatar
Rounders
My 07 needs this periodically,there was even a bulletin for that year. Why that year, not sure
Could be lots of things, when you are costing. It might be an issue all the time,but you don't notice cause when giving gas it catches itself, and just misses a beat
I had another bike, that did this for coil that would act up, but ohmed good.
For tps,in my case, it acted up variety rpms.
I'd IAC sensor cause free and easy.
Old Aug 8, 2023 | 11:31 AM
Rounders's Avatar
Rounders
11 o clock position on induction module is hole, behind air cleaner. Spray sensor cleaner in as you cycle kill switch/power,you should hear motor. Put some paper towels to catch gunk.
At least on my year .
