Weird issue
Old Sep 12, 2023 | 07:38 PM
Kerr8005's Avatar
Kerr8005
Default Weird issue
ive had this bike nearly 10 years. ‘12 Ultra Classic, 103, TTS100 cams, ThunderMax ECM, no cat, baffled exhaust…. I have literally replaced everything on the bike; new CVO TWG, Injectors, Map Sensor, Tank Innards, everything that bolts onto the motor and tranny.
Iget about a 1/4 from the house and the bike acts like it’s gonna die. I get turned around, give it everything it’s got and it runs like it should. I start slowing and it acts like it’s gonna die again.
This issue started earlier this summer, and started throwing parts at it, grenade style, just to see what sticks I guess and too cheap to take it to the Harley dealer.
Could a blown head gasket make the bike act like this? I do see a little oil on the front cylinder and it does seem like it sounds like George Jetsons car… if that makes sense?
anybody have any thoughts?
Old Sep 13, 2023 | 06:02 AM
jake24lt's Avatar
jake24lt
If you suspect a head gasket, then do a compression or leakdown test
Old Sep 13, 2023 | 06:38 AM
RANGER73's Avatar
RANGER73
Stuck umbrella valves or plugged breathers.
Old Sep 13, 2023 | 08:20 AM
memphisharley's Avatar
memphisharley
any codes. was the temp sensor one of the parts you changed.
Old Sep 13, 2023 | 09:30 AM
Kerr8005's Avatar
Kerr8005
No codes, changed the temp sensor also. Actually every electronic part that bolts onto the engine or tranny.
Old Sep 13, 2023 | 01:34 PM
WP50's Avatar
WP50
This isn't the thread I was remembering but think it's worth a read for you.
https://www.hdforums.com/forum/ignit...e-driving.html
WP
Old Sep 13, 2023 | 10:31 PM
Max Headflow's Avatar
Max Headflow
Map sensor don't do anything on a tmax..
Did you replace the crank sensor?
Old Sep 14, 2023 | 10:36 AM
Kerr8005's Avatar
Kerr8005
Crank Sensor has been replaced also.
Old Sep 14, 2023 | 10:59 AM
Max Headflow
As soon as it happens, have you simply tried to cycle the ignition to see if it restarts? The ECM may be hanging up..
I had a weird issue with a Tmax where it would occasionally shut down mainly when it was cold and at altitude. Toggling the ignition would correct it.. It would only happen once a year. I was having a weird issue with the neutral switch toggling on and off fast enough that the light would glow dimly. I finally replaced the switch and I've never seen the problem since. Sounds weird for sure but I suspect that there was a bug in the ECM software that probably caused a stack overflow and the processor would crash.. BTW, been running the current Tmax for the last 70000 miles that did the problem.
One thing you might want to do is make sure you Tmax has the latest firmware.
That may not be your problem. You simply may have a ECU that is failing when hot..
About the only other issue could be fitting on the bottom of the tank. The coupling on the line going to the injectors can become flakey.
04CVO
Screamin Eagle CVO Models
Jun 13, 2020 04:41 AM
bigrobtemp
2014-2024 Touring Models
50
Aug 2, 2015 05:14 PM
crosshairs
May 19, 2013 09:12 AM
speakerfritz
Mar 1, 2013 12:40 PM
2006ultra
Feb 13, 2012 02:36 PM
