Testing Harley ACR
Old Sep 25, 2023 | 11:05 AM
sumncguy's Avatar
sumncguy
Default Testing Harley ACR
The harley tech told me that he tests ACRs with a battery. But .. he wouldnt tell me how to do it.
Does anyone know how to bench test an ACR using a battery ?
Old Sep 25, 2023 | 11:23 AM
jake24lt's Avatar
jake24lt
You could always use a compression gauge and try the test with acrs plugged in, and then unplugged. Obviously, a significant change in compression will tell you if they are in fact functioning.
Old Sep 25, 2023 | 12:52 PM
chopper_man's Avatar
chopper_man
Don't know if true or not but the shop I use told me ACR's only operate during fuel pump prime and are only effective during first crank over. Made to get rid of any residual cylinder pressure. Makes sense tho as even manual compression releases automatically close once pressure is built up.
For testing, you can listen for the click, but that only tells you they are opening, not if they are plugged, fouled, whatever. Better way would be with a compression tester. Put one in, crank a few cycles, turn bike off for a few, then just turn the ignition/run switch on and see if the residual compression is released.
Quite a few forum posts here on them:
https://www.google.com/search?q=test...&bih=744&dpr=2
Old Sep 25, 2023 | 06:23 PM
sumncguy's Avatar
sumncguy
Yep. Understand what they are and how they work. Want to know how to bench test them.
Old Sep 26, 2023 | 07:13 AM
Fat11Lo's Avatar
Fat11Lo
Just two wires?
Use jumper leads preferably with the positive fused, its just a simple coil and you should see the valve open when voltage is applied
Old Sep 26, 2023 | 07:25 AM
chopper_man
Originally Posted by Fat11Lo
Just two wires?
Great comment about fused 12v. That however would only prove it "clicks". To bench test an ACR you would need to build a jig of some type where it screws in, can be pressurized and verifies it relieves the pressure as well as the 12v source.
ACR----Compression gauge-----air source (Schrader, quick connect, etc)
Old Sep 26, 2023 | 10:03 AM
Fat11Lo's Avatar
Fat11Lo
Old Sep 26, 2023 | 10:57 AM
Buelligan666's Avatar
Buelligan666
That's the way I would test them... seems simple enough.
Old Sep 26, 2023 | 10:29 PM
HDkazHD's Avatar
HDkazHD
with ACR I've front giving 25psi lower than the rear. with ACR disconnected, both front and rear giving same psi. possible that one of the ACR opening more thus bleeding off more pressure? or one of the ACR is not opening as much thus higher psi?
Old Sep 26, 2023 | 10:50 PM
madmuthertrucker's Avatar
madmuthertrucker
I put 103 heads on my 96 and added the SE ACR's, so I wanted to check that they were working.. I compression tested them, then unplugged them and checked them again. It was a 50 psi difference, so I figure that they are working.
