Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I was talking to a mechanic who just tore down a hydraullic tensioner set up around 45k, where pads were gone, bad lifters, and debris. I thought that was early. I am going to replace my lifters replace pads since open to inspect at 70k this winter. I would add lifters to repladement list, personally.
Is this mechanic related to your machinist that said boring to 103 or 107 is bad and refuses to do it?
There has been concern for years, are you new to Harley, about cheapening of crank. Also some concern about timken bearing , which was discontinued in 2002.some people wondered when Harley about increased run out spec too.
Later year 88s they cheapened crank too.
I go to a professional shop, and he says same thing. Harley was chasing it's tail when they went to 96" with problems.
