95ci compression question
Old Jun 25, 2024 | 07:58 AM
chrispunk's Avatar
chrispunk
4th Gear
Default 95ci compression question
Hi all, I’m about to bore my 03 FXDX TO 95”. I had ordered some 10:1 pistons I was going to pair with a .027 head gaskets. The pistons went missing before they got to me. Rather than order another set from over seas I’ve ordered a set of 10.5:1 pistons.
my worry is the 10.5 with the skinny head gasket will push the compression too high and maybe cause pinging?
in the uk i think all fuel is minimum 95 now.
im running a feuling 525 cam and a mikuni 42.
currently making 91flb 74hp if it’s relevant.
im pretty happy with the torque( I wouldn’t grumble about a little more though.) mostly I’d like it to not have to work so hard on the motorway.
im not sure why other info is useful
cheers
Old Jun 25, 2024 | 08:37 AM
eighteight's Avatar
eighteight
Plug your numbers into the Big Boyz compression calculator
experiment with different H.G. thicknesses
Old Jun 25, 2024 | 09:05 AM
djl's Avatar
djl
That combination should be OK if 10.5 static is true; CCP about 190psi. However, the only way to know true compression would be to know chamber volume, piston dome volume and deck height; you have the other numbers which are head gasket thickness and cam intake close event.
Old Jun 25, 2024 | 09:12 AM
eighteight's Avatar
eighteight
When I did a similar build ( carb ) DJL recommended a programmable ignition.
Probably should be on your radar
( I also added manual compression releases which make for happy hot starts)
Old Jun 25, 2024 | 10:07 AM
chrispunk's Avatar
chrispunk
4th Gear
A programmable ignition is on my list.
Old Jun 25, 2024 | 10:29 AM
chrispunk's Avatar
chrispunk
4th Gear
This is what I’m getting from big boys, though the engines away for paint so I can check deck height or cylinder volume
Old Jun 25, 2024 | 02:02 PM
marcodarq's Avatar
marcodarq
the thing to be concerned with on this, to me, would be valve to piston clearance. I know the 525 cam is not a big one, but i'd still mock it up and clay it to make sure. as long as you have an adjustable ignition system, the rest can be dealt with. not knowing how the dome is on the piston that you get.
m
Old Jun 25, 2024 | 02:35 PM
chrispunk's Avatar
chrispunk
4th Gear
these are the pistons
https://www.wiseco.com/product/power...-piston-kit-6/
m
Old Jun 25, 2024 | 03:12 PM
djl's Avatar
djl
JMHO but I would not set up a carbed motor at the compression shown in the OPs BigBoyz results; EFI maybe if I knew the tuner was capable. I am running a 98" at a tad higher but had complete confidence with the tuner and have had no issues but, as I said, if the bike was carbed, I would keep CCP in the 190-195 range and/or corrected CR below 9.6.
As has been pointed out, a Daytona Twintec TC88 progammable ignition and manual CRs should be part of the plan per eighteight's post. I would return the pistons in exchange for one with a 6cc dome.
Don't disagree on marcodarq's post about mockup but for a different purpose. I would want to know squish which might make me decide to machine cylinders to 0.00" deck height and adjust head gasket thickness if necessary. We have been installing SE cams like with higher TDC lifts than the 525 forever so I don't believe piston to valve to be an issue but, having said that, if mocking up, why not check.
Old Jun 26, 2024 | 10:21 AM
Jake707's Avatar
Jake707
UK gas starts at 95 octane?! lucky! I wouldnt think pinging would be an issue with a higher octane fuel. Ive run 10.5 with .035 head gaskets plenty of times with no issues on California crap gas but, as mentioned above there are other potential issues with that set up and how it behaves on the street once tuned.
