Road king problem
Old Jul 14, 2024 | 03:39 AM
Jasesbike's Avatar
Jasesbike
1st Gear
Default Road king problem
Hey hd problem solvers
this isn’t for me but my neighbour he has a 2018 hd road king with a124 upgrade . The problem started at the beginning of winter as the outside temperature has dropped. The bike is parked under cover but not in a garage .
He went out and tried to start it but it was back firing through the air filter , took it to a Harley shop spent 700 on god knows what , and 2 weeks latter started doing the same thing . Took it back again and they so-called replaced the seals or gaskets on the heads .it Started at the shop took it home , parked it up for the nite . Went to get on it in the morning for a ride and did exactly the same thing . This cost him another 700 and still no answer . Is there someone out there who has had the same problem. Thanks
File Type: mov
Old Jul 14, 2024 | 05:20 AM
DeeRoe's Avatar
DeeRoe
first thoughts go to bad fuel, fuel filter issue, or an obstruction in the intake or air filter. Could be a bad air sensor, too.
Old Jul 14, 2024 | 05:36 AM
Jasesbike's Avatar
Jasesbike
1st Gear
The dealership removed all old fuel on the first time it happened, also replaced spark plugs . When the bike came back the second time the cone on the air filter was on the wrong way , some one there didn’t know what they were doing .
Old Jul 14, 2024 | 05:41 AM
Jasesbike's Avatar
Jasesbike
1st Gear
once the bike finally starts it runs fine , it’s like when the bike is hot it has no problem, it seems to be only in cold temperatures in the morning. We thought it maybe the oil as 20w50 is very thick and isn’t great in cold temperatures. But I did think about one of the sensors like you mention .
Old Jul 14, 2024 | 08:39 AM
DeeRoe's Avatar
DeeRoe
Check to see if your bike is throwing any codes. Hold down the trip reset on the clutch housing, and then turn on your ignition switch. The odometer should display codes for the ECM, etc. Write down the codes, if any, and see what it says.
The sensor I was talking about is the airflow sensor on the intake manifold.
Old Jul 14, 2024 | 08:47 AM
cobra23's Avatar
cobra23
Sounds like another incompetent dealer service department. Too many of them out there. Find an Indy who actually knows how to diagnose and fix Harleys.
Old Jul 14, 2024 | 11:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How about telling the guy to join the forum and ask for help himself?
It is difficult enough to help people over the internet without going through an intermediary.
Too much can get lost in the process, we don`t know your experience level or the guy you are trying to help.
Old Jul 14, 2024 | 03:16 PM
Jasesbike's Avatar
Jasesbike
1st Gear
thanks , but he doesn’t have a computer and asked me to do it , we wrote this together.
Old Jul 14, 2024 | 03:46 PM
memphisharley's Avatar
memphisharley
did he try contacting the shop that tuned it
Old Jul 14, 2024 | 04:38 PM
Jasesbike's Avatar
Jasesbike
1st Gear
he’s definitely had a guts full of them , but yes he has and is speaking to someone there again today .
Slamfire
Electrical/Lighting/Alarm
Aug 21, 2022 09:16 AM
troverman
Jun 6, 2014 12:12 AM
Sharkman
Sep 12, 2013 10:55 PM
sicroadking
Mar 29, 2008 12:23 PM
MOking
Sep 30, 2007 08:11 PM
