2015 CVO Twin Cooled Head removal
Old Nov 7, 2024 | 03:26 PM
ShoreRider's Avatar
ShoreRider
Default 2015 CVO Twin Cooled Head removal
Has anyone removed their heads on a Wet Head Twin Cam? Specifically, how did you remove the coolant pipes from the heads? The service manual says to use Snap-On tool LDTSP4 or P/N B-41623. I've never used either of these tools and before spending a hundred bucks on a 2x use tool, I'd like to find out if there may be another way.
Old Nov 7, 2024 | 05:48 PM
Rusty Springs's Avatar
Rusty Springs
I disconnected the steel tubes from the manifolds on the rubber hoses and left the tubes in the heads. I wasn't doing any head work though.
Old Nov 7, 2024 | 07:32 PM
ShoreRider's Avatar
ShoreRider
Well ****...that's the reason I'm pulling the heads, to send them off for milling, porting, and polishing.
Let the search for knowledge continue...but very much appreciate the reply!
Old Nov 7, 2024 | 08:51 PM
marcodarq's Avatar
marcodarq
For almost every snap on tool like this, there is a lower cost alternative, usually from companies like Lyle and others that do the same job without the price tag. Take a trip to your local HarbornFrieght store or look on their website. Im sure there is an alternative.
m
Old Nov 7, 2024 | 09:40 PM
Ya Tigor's Avatar
Ya Tigor
Lisle 22710 will do the work being same tool as Strap-on
Old Nov 8, 2024 | 04:34 AM
ShoreRider's Avatar
ShoreRider
m
Thanks for the info!!
Old Nov 8, 2024 | 04:36 AM
ShoreRider's Avatar
ShoreRider
Thanks, very much appreciated! I can always depend on forum members!
wilburbill
Engine Mechanical Topics
Aug 2, 2021 12:08 PM
Ralphie514
Screamin Eagle CVO Models
May 20, 2020 08:43 PM
reacher
Aug 26, 2013 09:00 AM
Jim Dawson
Aug 23, 2013 09:46 PM
Justride53
Aug 19, 2013 11:45 AM
