Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
hummmm
only other option is fly it and watch it
do not forget valve springs, just as catastrophic
you can always fly cut the pistons but check the mfg before doing so.
been there done that modifying two cycle pistons for 5 port.
hummmm
Thanks for this information. First I did not understand your post, because I did not know what fly-cutting was. Then I googled. Well, thats a smart thing to do if clearance is not enough. This forum makes me wiser.
Whatever you do.. Clay it. Dont trust math or anothers results.. Clay it. Get some super light springs to install and rotate the assembly.
I like a minimum of 40 thou myself. At higher rpms and heat growth you want some cushion.
