Boring TC Cases...
Old Feb 6, 2025 | 07:04 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Boring TC Cases...
Is it possible to bore Twin Cam cases to accept 4.25" pitons???
Old Feb 6, 2025 | 07:45 AM
wfolarry's Avatar
wfolarry
Sure but you'll need cylinders from someone like Revolution Performance.
124″ Twin Cam Monster Big Bore Kit – Black Highlight | Millennium Technologies
Old Feb 6, 2025 | 07:59 AM
98hotrodfatboy
I know nikasil cylinders are good for two stroke motors but I didn't think they were advisable in the Harley air-cooled motors.. Thoughts??
Old Feb 7, 2025 | 12:49 PM
marcodarq's Avatar
marcodarq
yes you can bore the cases, i don't see why nikisil would be bad?? porche has used if for years and i had a turbo 944 running 14-17psi boost for a long time,i rode this hard and put it away wet regularly!!! when i blew a head gasket, i went to replace it and the car had well over 200,000 miles on it, no issues in the cylinder bores. I also work on Aprilia motorcycles with have used Niki from back in the days when they used Rotax engines, again very rare to have an issue related to that.
I have talked to the people at Revolution in the past and got a great feel from the conversation,,,,have considered this myself as well, just don have the cash.
do it!!!!
m
Old Feb 7, 2025 | 02:16 PM
wfolarry's Avatar
wfolarry
Used them on a race bike. Never had a problem.
S&S probably has a kit as well. The have the tin liner cylinders like HD has for their big bore kits.
Old Feb 7, 2025 | 02:36 PM
ntraindavefl's Avatar
ntraindavefl
Bob my avatar pic is TC 4.250 cylinders from RevPerf. 10+k miles and it’s quietest motor I own. Scoped cylinders recently and looks great, zero oil burn, would do it again
Old Feb 8, 2025 | 03:28 PM
Max Headflow's Avatar
Max Headflow
I have rp nikasil 4 1/4 bore cylinders on my 131.. For some reason RP screwed up finish on the first cylinders that they sent out. They also used the wrong rings on the pistons. Moly filled top ring and Nikasil don't mix well together. I suspect they have it figured out by now.. One thing you need to make sure of is that you use cometic MLS head gaskets that have the fire ring embossed on the middle layer or you use copper head gaskets. The cometics without the embossment will eventually leak between the cylinder and the stud hole.
Old Feb 8, 2025 | 04:00 PM
98hotrodfatboy
Honestly Max, If I do go this route it will be with a set of S&S 4.625" wheels.. Go all the way or go home... LOL..
The only issue there then would be the rest of the drivetrain (the trans, belt and complete clutch basket.
I imagine this combo would be 155/155 plus.. Whoa Horsey......!!!!
Old Feb 8, 2025 | 04:45 PM
Max Headflow
Mine made 144/146 though a 48mm Mikuni.. About 16 years ago.. Last time I ran it, it made 135 at a dyno shootout (no torque) but the CR was dropped from 11.5 to 11 when the CP pistons were swapped out for WIseco and I add a restrictor to the exhaust to quiet it down.
Old Feb 8, 2025 | 05:43 PM
98hotrodfatboy
I'll bet that moved very well...
arnie54
2014-2024 Touring Models
14
Feb 4, 2024 09:58 AM
Slantsix225
Twin Cam Motors
19
Dec 14, 2021 06:32 AM
fxd666
Engine Mechanical Topics
Apr 9, 2015 12:37 PM
jurgie
Exhaust System Topics
Mar 31, 2012 08:31 AM
Boxer 6
May 26, 2011 06:48 AM
