Pushrod Cover Install Help
Old Apr 4, 2025 | 03:00 PM
telefonica's Avatar
telefonica
1st Gear
Default Pushrod Cover Install Help
Hey guys.
I just replaced my lifters and installed adjustable pushrods and am now installing some "quick release" (or whatever they're called) pushrod covers. However, there aren't any instructions. I have a question about the two different washers that come with the kit (see pic). Which washer goes where?
Thanks!
Old Apr 4, 2025 | 06:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The pushrods are already installed?
Old Apr 4, 2025 | 06:01 PM
tngarren's Avatar
tngarren
uh oh...
Old Apr 4, 2025 | 10:28 PM
MotoJockey's Avatar
MotoJockey
Did you try contacting Drag Specialties? Or going on their website to see if they have instructions that you can download?
Old Apr 5, 2025 | 12:40 PM
djl's Avatar
djl
Could that kit be for an Evo? IIRC, Evo pushrod covers use a washer at the top and bottom of the cover where they seat into the tappet blocks and the cylinder head but there should be 8 washers; 2 at each tube.
Old Apr 5, 2025 | 12:47 PM
Buelligan666's Avatar
Buelligan666
What are we working on?
Old Apr 5, 2025 | 01:55 PM
Weeboy1's Avatar
Weeboy1
What’s in your hand looks like #6 & #7 flat washer and Oring
But more info would be nice…
Old Apr 5, 2025 | 02:06 PM
roussfam's Avatar
roussfam
Removing pushrods?
Old Apr 5, 2025 | 08:05 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Those definitely appear to be for an Evo motor.. The larger diameter flat is a washer that has one side that's machined and faces up when placed in the lifter block Which is under the print #9 in the picture above.. As for the other washer, that goes under the spring #5 as in the picture above which is #6 and helps to apply proper pressure on the o-ring for the lower half of the pushrod tubes.
Old Apr 6, 2025 | 11:25 AM
ntraindavefl's Avatar
ntraindavefl
Exactly. I also like to install the push rods then install the covers, but somehow it never works.
