Adjustable stabilizer link
Old Apr 26, 2025 | 09:08 PM
Weeboy1's Avatar
Weeboy1
If a mod wants to move this to the “frame, suspension etc sub forum it may be more appropriate there.
Old Apr 29, 2025 | 05:31 PM
Weeboy1's Avatar
Weeboy1
Originally Posted by NEWROADSTER
Try one of these rear stabilizers that are fully adjustable. It made a noticeable difference on my bike. Not only do they work, they are not expensive. Alloy Art
Curious when you installed yours did you elevate the bike on a Center stand, Center stand with weight on the rear end or just install it with it on the jiffy stand?
Old Apr 29, 2025 | 06:56 PM
NEWROADSTER's Avatar
NEWROADSTER
Mine was on a J&S Jack sitting more or les level.
I did notice in the picture, that the chinezem copy looks like it puts the adjustment rod closer to the back of the frame.
Old Apr 29, 2025 | 07:36 PM
Weeboy1's Avatar
Weeboy1
It likely does. There are 2 different parts dependent on bike year. Mine is an St09 yours is I believe is an M8 model. They are slightly different due to model years. The m8 adjuster rod is slightly closer to midway of the bracket The parts for my model year seem identical.
thanks for the reply re install. I did mine on the jiffy. Should have thought better. Will recheck.
Old Apr 30, 2025 | 08:44 AM
Slingshot383's Avatar
Slingshot383
The will not fit if you have a Bassani 2 into1 exhaust system, sadly.
Old Apr 30, 2025 | 10:04 AM
Weeboy1's Avatar
Weeboy1
Good point and likely same with other exhaust depending on the sweep of the pipe on the rear cylinder.
Old Apr 30, 2025 | 10:18 AM
NEWROADSTER
I agree, it will fit with the Thunderheader on the new 23.5 up bikes.
Srrmc
Sep 17, 2022 06:39 AM
marcodarq
Feb 8, 2020 05:12 PM
Tony Steele
Jul 7, 2015 02:26 PM
gtrplyr
Oct 12, 2011 03:37 PM
