Putting cases back together
Old Jun 6, 2025 | 12:19 PM
tinymike66's Avatar
tinymike66
Default Putting cases back together
Any suggestions on the best sealant for putting cases back together.
I've heard
yamabond
threebond 1841
Lotite 518
permatex 518
The right stuff
Old Jun 6, 2025 | 12:33 PM
Rounders's Avatar
Rounders
There is what is in the back manual. I used some avaition stuff a friend had. But I would buy stuff in manual if I had too
Old Jun 6, 2025 | 12:54 PM
Tommy C's Avatar
Tommy C
Yamabond #4 is what I've used in the past. Three Bond 1211 is the same product as far as I can tell.
Never mind what Rounders is posting as he is here just to confuse and agitate folks.
Old Jun 6, 2025 | 04:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Permatex 518 is what I recommend, it is an anerobic sealant (it only cures in the absence of air).
It will not cure until the parts are joined together, so any stuff that gets into the cases will dissolve when oil hits it and go out with the next oil change, no chance for it to cure in little bits to clog up any passageways.
2019 Electra Glide Project:
Old Jun 6, 2025 | 05:00 PM
marcodarq's Avatar
marcodarq
HD grey high performance sealant
pn#99650-02
m
Old Jun 6, 2025 | 05:01 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Permatex 518 has kept my 77 XLH together with no leaks for 8 years. HIGHLY RECOMMENDED!!!!!
1977 XLH 1000
1977 XLH 1000
Old Jun 7, 2025 | 01:57 AM
NorthWestern's Avatar
NorthWestern
Use an anerobic sealant! The Permatex 518 as mentioned above is a perfect choice.
Old Jun 7, 2025 | 04:54 PM
98hotrodfatboy's Avatar
98hotrodfatboy
You know, I always thought about that. I don't like the fact that Yamabond never really hardens.. As a Steam fitter I've used Permatex a lot.. Just need to let it cure properly.. But the whole thing there is that it's a bitch to get it back apart if repairs are necessary..
My Evo was put together with Yamabond and is now seeping... Another project someday down the road.
Old Jun 7, 2025 | 05:02 PM
Uncle Larry's Avatar
Uncle Larry
We all have our "go to" ... I've done many two stroke and four stroke ( several HD's ) and have never had a seeper / leaker ... Might not ever do another one but if I do I'll ( more than likely ) use the Yamabond ":>)
Old Jun 11, 2025 | 05:29 PM
tinymike66's Avatar
tinymike66
So I been looking everywhere
all I can find is permatex moto seal or Uktra gray
Do any these work ?
Canada sucks for this kind of stuff
