Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Today it's mostly bad metallurgy and corner cutting hardening with the components, lift are just one of many items suffering from this problem and it's spread across many mechanical applications not just harleys. Cam choice and riding habits don't help and personally I don't think the current synthetic oils are up to it. It's great for most other engine wear & lube points but crank pins and lifter rollers are getting abused hard. We lost the the occasional roller in the shovels, come the evo, multi weight and synthetic oil, lifter problems became regular thing, see more of it every engine generation
totally agree, I think even the ebay sold ones that say they are OEM are 2nd run or the "blems" that didn't make the cut, and the cut itself is not that great haha!
__________________
The best AMERICAN MADE products you can get! Innovation, quality and the piece of mind that you are buying from a company that CARES if their customers are satisfied!
I definitely agree about the synthetic oils. We suggest NOT using synthetic in ANY of our builds because it simply loses viscosity when it gets hot. Another point about synthetic oils is they do not transfer heat as well as a Dino oil does, so in your oil cooled bike, it makes it run hotter thus breaking down the oil even worse.
I think a lot of them are just plain counterfeit, packaging and all, just like a lot of the precision components being sold by unscrupulous vendors.
Even reputable vendors get had, Hell they are hustling counterfeit Blue Streak points now, packaging and box look legit. Inside, fake as a strippers smile
Not sure what to believe anymore. Seems like what the majority of what Ive read is the opposite.
Do you have documentation that supports this theory? It is a fact ,that full synthetic oils are more heat stable than conventional oils.
Evo lifter problems existed before syn was a thing on Harleys, the factory redesigned the lifter in the mid `90s, and since then the OEM Evo lifters have been good.
More failures every generation, but Shovels weren`t putting out the crazy horsepower numbers that the TC`s and M8`s are seeing.
The late model lifter failures may be rare, but common enough that I get rid of OEM lifters as soon as a machine is out of warranty.
I disagree with the idea that lifter roller failures (or any other component for that matter) are the result of synthetic oil.
Quality US made lifters are not failing, it`s the imported junk lifters (OEM TC-M8) that are failing.
Junk Science
