Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looking for input on a question I can't find an answer to, hopefully not posting in the wrong place. Got a chance to pick up a used 21 1200 Sportster Iron on a deal, engine failed due a rod bearing on flywheel end. The guy has a 14 donor 1200 as well and I cannot readily find if these will play nice together or if it's going to be a giant headache.
So hopefully y'all can provide some insight here. Any meaningful input is appreciated!
P.S. yes, they are both Evo's. Had someone disagree with me that the 21 had to be a RevMax
Andy, so hypothetically for the hard parts there's no issues, just have to ensure you have the appropriate electronics and sensors? I'm very familiar with CAN BUS in the automotive world, just now starting to play with the motorcycle stuff. Thank you!
