2008 Nightster Head Leak
Old Apr 19, 2026 | 02:06 PM
ripto's Avatar
ripto
Default 2008 Nightster Head Leak
Bike has 7k miles on, it had a bit of a leak problem for a few years, nothing crazy, just enough to make the fins shiny and sometimes get on my pants. Had someone take a look at it and they replaced the rocker box gaskets. Now its much worse. They looked at it again and retorqued to double check they did it properly - no change. These pics are from after about a 15m ride. The shine on the fins, at the top and bottom of the black section make me wonder what it really could be - how could the middle section be dry but the top and bottom wet? Could there be a crack in there somehow? Not sure how it could have gotten worse from before to after the gasket replacement. The guy also gouged the black powder coat in four spots around those two bolts, so, yeah not very happy. My fault for not going directly to Harley I guess. I assumed they wouldn't work on something this old but I didn't ask.
Old Apr 19, 2026 | 04:28 PM
Tommy C's Avatar
Tommy C
I'm looking at the pictures on a phone, but it looks like the leak is from the gasket between the rocker box and the cylinder head.
Old Apr 19, 2026 | 05:07 PM
1TxBiker's Avatar
1TxBiker
I see what Tommy C sees, head gasket leaks.
Old Apr 19, 2026 | 07:20 PM
Tommy C's Avatar
Tommy C
No, not a head gasket leak, it's a leak between the lower rocker box and the cylinder head. Might even be a pushrod tube o-ring leak because it looks like there's some oil on the right side of the head, too.
Old Apr 22, 2026 | 05:23 PM
ripto's Avatar
ripto
Thanks guys, I'll try and find out exactly what gaskets the guy replaced.
Old Yesterday | 01:06 PM
ripto's Avatar
ripto
The part on the invoice is called "ROCKER KIT 07-12 SPTSTER" with a part number of "0934-1236". Is this what you guys would think would be the part needed?
Old Yesterday | 04:31 PM
marcodarq's Avatar
marcodarq
its rocker box leaks,,,,mre than one gasket involved in the set, they all need to be replaced when doing the job. look at the parts diagram.
m
Old Yesterday | 09:24 PM
JimL_15 Electra Glide's Avatar
According to Harley.
Aquadan005
Shovelhead
Apr 28, 2024 06:28 PM
duderino420
May 3, 2021 10:59 AM
DynaDude420
Twin Cam Motors
Jan 15, 2021 02:04 PM
gartec81
Apr 2, 2016 12:01 AM
frank1200N
Sep 2, 2010 08:54 PM
