TC 103
Old Jun 4, 2026 | 06:54 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Schex
@98hotrodfatboy If you still have those 110 cylinders, can you measure the bores down in the spigot area and see how much they're out of round?
@Schex
I don't have torque plates so I don't think my measurements are accurate.. Cold sitting on the bench are as follows..
At the very bottom of the spigot the thrust side measures 4.009" and the non thrust side measures at 4.0035"
By the way they are for sale, they have approximately 5k on them and the piston valve reliefs are cut out for 2.020" intakes and 1.630" exhausts.. +3 cc domes.. I believe they are S&S..
Old Jun 4, 2026 | 08:34 AM
Schex's Avatar
Schex
And that's the problem with the thin spigot cylinders, they get egged, almost .006" out of round, the front cylinder is usually the one with more from what I've experienced.
@tinymike66 This is my point, with no time line, you can get your cases bored.
Get some already "seasoned" used CVO 110 cylinders on Ebay. You may have to paint them with HD texture paint if they are grey, no big deal.
Get those bored and buy new pistons.
All for near the cost of a drop on 110 kit.
Minus the thin spigots that warp.
Old Jun 4, 2026 | 08:55 AM
98hotrodfatboy
Again these measurements are not accurate because I don't have torque plates, so with them mounted in the cases and a top torque plate used it's very possibly you will get a different measurement than what i did on the bench. I believe the thrust side diameter will always be a little bit different and the non-thrust diameter..
OP, if by chance you do decide to Bore the cases, at that point I wouldn't even bother with the set of used 110" I go straight to brand new 117's, like I did.. You ain't going to believe the power difference. I just did a thousand foot measured run from the 110 setup to the 117 setup and gained 0.80 seconds with the 117.
Old Jun 4, 2026 | 09:55 AM
tdrglide's Avatar
tdrglide
Originally Posted by tinymike66
doesnt S&S or FuelMotto make a direct bolt on kit to being the 103 to 110 or maybe it was 107? I know S&S has that sidewinder kit, direct bolt on to bring the 88 up to 100
Several shops offer bolt on 107" kits. Bored out stock cast cylinders, ported heads. Cylinders seem to stay stable. If money is no option, then go 117". At least
skip the 110
Old Jun 4, 2026 | 12:23 PM
Max Headflow's Avatar
Max Headflow
@Schex
One thing to note is that torque plates wont make the cylinder spigots smaller. They can do some at the base gasket but if you got 2 measurements on the outside of the spec on the spigot. If both are oversized, torque plates might bring one on a little but if so, the other will get bigger. Now, IMO, the spigots can be a little larger than the rest of the bore. All it has to do is hold the piston straight enough for it to slide back into the rest of the cylinder.
BTW how long were the spigots on you 117?
Old Jun 4, 2026 | 01:46 PM
98hotrodfatboy
I just got off the phone with S&S and they tell me the spigot length on 4.125" cylinders is 1.850" @ .120" thickness.. I knew that they were a lot longer than my 4.0" cylinders..
mgb1
17
Jan 5, 2026 07:38 AM
Drumlord
EVO
11
Oct 24, 2018 08:10 AM
Shrink
Engine Mechanical Topics
Apr 28, 2015 03:56 PM
cmashark
Sep 20, 2009 09:56 AM
cardboard
Jan 18, 2007 01:18 AM
