Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
It's been stated that the new HD hi flow oil pump does not use the rear o-ring that is used on the original pump. THIS IS FALSE! The new pump - according to HD requires that you replace the original #11301 o-ring for use with the new hi-flow pump. This may explain the sump issues thst some have mentioned? I'm no expert; just learning as I go! I've been working on my (2002 FXDWG) 95" BB/Andrews TW37b cam build for several days now. I could have had it done by my local tech - but what fun would that be? I just hope the 2009 heads work out okay. (Chewing my nails...)
I'm going with:
New BB cylinders
New 44 CV Carb
New BB Pistons (Harley/Kobenshmidt)
Andrews TW37b Cams
James .036 head gaskets (or Cometic .030) I'm hearing about leak issues with the Cometic...
Stock 2009 Dyna Heads
Daytona Twin Tec Ignition (If I have Bean re-work the heads to 9.5 compression or higher)
I want to keep the compression in the lower range. 9.5 sound good. I don't want my CCC to be over 180 psi. I'd prefer 178 psi... I'm thinking that comp releases may still be a good idea?
First I heard of this. The new pumps don't use the o-ring on the front of the oil pump where it goes against the cam plate as the older ones did. The rear o-ring has been used on the old ones and gets used on the new ones.
