HI OIl Use
Old Oct 29, 2011 | 10:27 AM
hdrider98ci's Avatar
hdrider98ci
Default HI OIl Use
I have a 2000 fxdx with a 98ci kit 560 lift cams screaming eagle oil pump/cam plate s/s crankcase breather gear, dorhtery mist free head breathers. The engine runs great but it looses about 3/4's of a quart of oil in about 500 miles. the plugs show no sign of burning it, I have the breathers routed to the air I get a little snot out of the and sometimes a little water. The exhaust is dry. Any fresh ideas would be great.
Old Oct 29, 2011 | 12:11 PM
kkiley's Avatar
kkiley
That is a lot of oil to blow thru. Start with a leakdown test and see what you find. More than likely it's rings/valves causing your oil issue. Time to freshen up that top end.
MrWhitaker
May 26, 2017 03:22 AM
shortyboz
Mar 3, 2016 01:01 PM
Roadkingdingaling
Oil Archive (no new posts)
May 5, 2014 11:34 AM
jerseyjeff62
Jul 5, 2008 09:40 AM
toolbox
Jul 20, 2007 10:14 AM
