Cam decisions
Old Feb 23, 2012 | 10:39 PM
Kaycee's Avatar
Kaycee
Cool Cam decisions
Tying to pick the right cam is sure confusing,I am trying to get one for my 05 stage 1 88 FXDWG.At least I have it narrowed down to half dozen or so lol ,I ride mostly highway 1 up,I don't have a tach so no idea where I am at as far as rpms when riding.Would like to go 95/7 in the next yr or 5.I would like just a little more hp/tq for now.I have talked to several indys and they all have there favorites.I was looking at Andrews 26 or37,S&S 510 chain drive,Dave Mackie 510,SE 203 OR THE 204 .My crank run out was .003 the cost of the gear drive is the kicker for me Any feed back would be much appreciated.
Old Feb 24, 2012 | 06:45 PM
Kaycee's Avatar
Kaycee
OK 85 views and no replys guess I'm the only one left with a stock 88
Old Feb 24, 2012 | 07:05 PM
Sash302's Avatar
Sash302
SE 204 is a nice cam.
Old Feb 24, 2012 | 07:12 PM
BlackSpecial's Avatar
BlackSpecial
Well I don't have an 88, but I sure like my Andrews 26H cams!!
I know what you mean tho about cam choice. I just looked around at some dyno sheets and read up on HTT.
Amazing what a cam change can do for just about any bike.....providing it's the right cam.
Old Feb 24, 2012 | 10:43 PM
Kaycee's Avatar
Kaycee
I read where the 204 like a little more compression,around 9.5 to run it's best ,Sash r u running it in a 88.I am stock comp.
Old Feb 24, 2012 | 11:17 PM
Cat Mech's Avatar
Cat Mech
I ran the Andrews 26 in my 06 88" Wide Glide. I have now stepped up to the 95" with the same cams. I love this cam set up it works great.
Old Feb 25, 2012 | 02:40 PM
ocezam's Avatar
ocezam
The relatively low compression of the 88" (9.0:1) compared to the 96" (9.2:1) or the 103" (9.6:1) makes cam selection a little narrower than the bigger engines. On your list I'd take off the SE204, the SE203 would be a bit better. I'd also remove the Andrews 37 and add the 21.
If your looking for low end torque go with the Andrews 21. The others are great midrange cams.
My 2 cents...
jrdfatboy
Apr 6, 2014 09:12 AM
monkey sammich
Jan 31, 2012 03:02 PM
cooldude
May 10, 2008 01:10 PM
cwilks
Apr 14, 2007 11:36 AM
hawnstar
Feb 6, 2006 04:17 AM
