collapsed lifter?
Old Mar 30, 2013 | 10:53 AM
Oldfart666's Avatar
Oldfart666
Default collapsed lifter?
2000 Heritage Softail,Carb. Put the bike away in the fall,ran great! Last week took it out to fuel it up.Started fine,not a tick. Rode to the gas station, filled up(premium of course) headed back home,then I heard a racket from the (sounded like)front rocker box. Pulled over checked oil level,fine.No external problems noted. Bike started right back up no real problem other than the noisy rocker box. Rode home gently,parked bike. After engine was cold restarted it and quiet as a church mouse...until engine oil was warmed then same noise! Have pulled rocker covers,looks fine. Pulled rockers off,look fine. pulled pushrods and tappets,they LOOK fine. Noise only when engine warm.No power loss in town riding. Winter before did adjuster shoe conversion(hydraulic slippers,oil pump,screaming eagle cam plate,andrews 21H cams) Consensus is bad lifter,but they seem fine. Ideas?
Old Aug 9, 2013 | 04:36 PM
springers4ever's Avatar
springers4ever
i see that this is an old question , but , i had the same many times , but because of high spring pressure and high lifts , ...take the lifter and see if you can push in down by hand ...if so ...it good chance it is the bad one ...or when trying to readjust the rods ,one seems very ez....it may be the problem ....but sounds like you on the right track ...
Eustus2000
Shovelhead
42
Oct 15, 2021 05:42 AM
HD_Matt
Engine Mechanical Topics
Mar 21, 2015 09:37 AM
Oldfart666
Exhaust System Topics
19
Apr 20, 2013 01:51 PM
roundy
Mar 30, 2013 04:30 PM
alvinlee
Mar 21, 2007 12:46 PM
