Engine break in
Old May 9, 2013 | 10:20 PM
Customfab's Avatar
Customfab
Default Engine break in
Just completed a 107" up grade to the 96" TC in My 2009 Rocker C and have been reading articles on the Internet regarding easy and hard break ins. When I first got the bike I took it relatively easy for the first 50 miles and then after that oil change I rode it as though the break in was complete. That did not seem to hurt it and it has never burnt any oil. I'm leaning towards Motomans hard break in procedure this time because I'm pretty sure that it works on liquid cooled engines so why wouldn't it work on an air cooled engine.
I've read quit a few articles (including S&S and HD) and the consensus appears to be almost a draw but I would appreciate any opinions and especially was wondering if anybody had (or knows of) a catastrophic failure due to the hard break in procedure.
Thanks in advance,
Old May 9, 2013 | 10:38 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I'd never do a "hard break in", mainly because the people who service the bikes say not to. If I did, it'd probably blow up.
Old May 10, 2013 | 08:28 AM
big cahuna's Avatar
big cahuna
If you want to form an opinion try this. Look up all the top mfgrs sites. Look up what each tells you how to perform an motor break in. I haven't seen one that recommends that says flog it out of the box. I doubt S@S will replaced a motor that blew apart due to the abuse you put to it, by not following their procedure. Do what you did before that worked.,,
Old May 10, 2013 | 01:16 PM
smitty901's Avatar
smitty901
Just ride it.
There is no magic or secret break in trick that will make it last longer or run faster.
Every once in a while over a few beers and a good smoke some they come up with some new 30-60- or 60-90 100 scam to pass off and laugh like heck at everyone that falls for it.
Ride it.
Old May 10, 2013 | 01:32 PM
lightweight bob's Avatar
lightweight bob
Default Motoman break-in procedure
Thanks in advance,
I agree with Motoman's procedure. It's tried and true and used it for years on various
engines - air and water cooled. Heat cycles and remembering to use engine braking to
suck particle build up out of the rings are important. Just NO lugging or extended high
rpm running and it'll be broke in in 500 miles.
Old May 10, 2013 | 02:08 PM
smitty901's Avatar
smitty901
Heat cycles. send the bike to me for 100 dollars and hour I will break it in and ship it back don't fall for the BS. Just ride same as you owners manual says and you be just fine.
Old May 10, 2013 | 03:29 PM
lightweight bob
Default Motoman break-inprocedure .............
www.mototuneusa.com/break_in_secrets.htm
Opinions are like a$$h0les - everybody has one but it doesn't mean you gotta like the
smell of theirs.
mysticwolf
Feb 2, 2022 01:34 PM
XFXDX
General Topics/Tech Tips
Apr 20, 2015 10:02 AM
JC in Colorado
Apr 6, 2013 04:51 PM
Anthony8858
Sep 15, 2009 09:17 AM
pococj
Oil Archive (no new posts)
13
Jan 10, 2006 03:17 PM
