Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
71 xlch
what mark should show up in the crankshaft hole on the left when the breather is lined up in the notch for camshaft timing purposes.
I have a line, which is pretty close to TDC for the rear cylinder. I want to say that's 180 degrees out?
