intermittant oil burning
Old Sep 24, 2013 | 05:37 PM
46u's Avatar
46u
Does yours have the engine breather tube going in to the air breather or has this been changed? 89 is before they started having the engine breather throw the heads. Have you ever had a problem with the dip stick blowing out? What does the bore look like? If you replaced the intake guide seals you should have all so replaced the exhaust to. At 10K since a rebuild the cylinders should still look almost new if it was bored and assembled correctly. Yes leak down test should show this but if the compression ring are good and the oil ring is bad a leak down test will not always show this.
Recon Dad
May 24, 2015 10:11 AM
mclldavidson
Jun 14, 2014 05:31 PM
walkerinin
Aug 25, 2012 01:23 PM
nemesistech
EVO
Jul 14, 2010 08:37 AM
lionsqrne
Jun 19, 2007 07:11 PM
