Compensator upgrade?
Old Apr 3, 2014 | 05:20 PM
peterjamesbenson's Avatar
peterjamesbenson
Default Compensator upgrade?
Hi fellow riders
I just want info on how a compensator upgrade will benefit my bike. I was offered an upgrade by an indy shop for $300 and he said will be great. I would like to know what to expect.
Old Apr 3, 2014 | 05:29 PM
gusotto's Avatar
gusotto
No info given as the what the "upgrade" involves.
Old Apr 3, 2014 | 05:32 PM
soft 02's Avatar
soft 02
2014 comp and a plastic tray that is glued to the primary cover. No reports as to how good it really is yet though.
Old Apr 3, 2014 | 07:22 PM
peterjamesbenson
he said will replace the compensator sprocket and chain
Old Apr 3, 2014 | 08:37 PM
gusotto's Avatar
gusotto
But with what is he using?
SE compensator (improved 2014) or after-market?
I had mine replaced with the earlier SE compensator.
Now they have an even newer model.
Old Apr 5, 2014 | 06:26 PM
Kiwirob's Avatar
Kiwirob
OP has an '02 Fatboy in the garage. SE compensator won't fit. Not sure of an up-grade for pre '06 Twin Cam bikes - Rob
Old Apr 16, 2014 | 08:37 PM
factoryhdtech's Avatar
factoryhdtech
The new SE compensator you speak of is a good upgrade. HD has improved the the overall "throw" characteristics of the comp assembly, and it is now OEM equipment on newer bikes. You can expect improved starting, ie... The starter is less likely to "bounce off the ring gear, and shifting should feel smoother with a better neutral "find zone". The plate that is epoxied to the primary cover is designed to properly direct fluid towards the new needle bearings that will be installed behind the comp bolt. I would highly recommend this upgrade.
Old Apr 17, 2014 | 09:51 AM
djl's Avatar
djl
There is an aftermarket upgrade for the late model compensator, the Compensaver; good reports so far. Hoban Brothers, AKA Darkhorse, also has an upgrade but not sure if it has come to market yet. Not crazy about the glue fix from the MoCo.
There is no "upgrade" for the early compensator. The Bellville springs can weaken but that can be fixed by adding a spring or replacing the Bellville assembly. If maintained, the early compensator/chain will last a long time. Have seen them go 75K miles with no issues, if lubricant is changed and chain adjusted per the service manual.
Old Apr 17, 2014 | 09:53 AM
soft 02's Avatar
soft 02
Was thinking about emailing John again to get a report about his new comp. 12k on my gen3 comp and its starting to rattle.
Old Apr 17, 2014 | 08:26 PM
WB's Avatar
WB
I have had two installed in the last 14 months and they are still crap. Haven't had the latest and greatest installed and hope I don't have to. Current comp is rattlin a bit on first cold clutch release tho... Keep them rpm's up guys!!!!!!
